Hello guys,
Saturn sound used both tubes the 407a and 408a, the 407a would have been labeled as UCC88 in the European tube code.
The 407a is 2x 20V/50mA version of the 2C51, what is in essence nothing else than a commercial grade ECC88 with a different footprint.
Running both triode haves in parallel and the filament in series gives you a replacement tube for a VF14 that will work close to the specs of an VF14.
But of all the 407a tubes I found, none of them was mic grade material, even the so called 'super-tube' Western Electric ones did not meet the simple VF14 noise specs.
The 408a is na EF95 with 20V/50mA filament, so with a dropping resistor, a direct replacement could be archived.
But here again, not the WE/Northern Electric, nor the Ericson, that were supposed to be high grade tubes, are good enough to be used in a U47.
However, the 408a/VF95s specs are pretty close in impedance as well as technical data, the head room is about 5dB less.
The tube in the pic is not Ericson, WE or RCAs because it is missing the black nickel plates.
Putting a glass tube in an metal container might be marketing, but it is still a drop-in replacement.
If someone wants a U47, buy a Neumann U47 with a VF14. If you do not have the cash nor the cash to keep the great sounding museum piece running, get a new mic.
Best regards,
For a fair and honest discussion of the subject, it should be disclosed that my friend Oliver is a supplier to Telefunken-USA. K.H.
