el duderino wrote on Tue, 13 January 2009 11:25 |
does the mix dream always send signal to the direct outs?
Yea, the Direct Outputs are always in motion. Anything you patch into the channel inputs, will feed Direct output without question.
Quote: |
Affirmative Adam. Thanks. Now if I wanted to use the MTC along with the MD, how would, should or could I wire that up correctly as it doesn't have obvious inputs that I am familiar with...some of it's inputs/outputs I don't even know what are for...has 4 2 track outs, and 3 pair of monitor speaker outputs. That I can see. I feel like an idiot trying to figure out how all this stuff should be wired up. Confused It helps if things are labled obviously. Usually I can catch on to the obvious. When I see "Headphone Out" or a headphone cymbal I know I can plug headphones in there. "Cue Mix" and "Musician" and "Slave" I'm not so sure if those are inputs or outputs. I bet there is a manual for all this. I just thought of that. Typical.
Here is the deal Adam;
The SPL MTC is as versatile as a monitor controller can get. You have several well thought out features in that box, that for the purpose of this discussion, we'll leave out for the time being. What you want to pay attention to, is the multiple stereo inputs on the MTC that will in result, feed your monitoring system with a really high quality attenuator before the speakers. You also have a Monitor feed on XLR from the Mix Dream, [in addition to another master buss output from the DB25 on the rear] so in reality you have three ways of feeding stereo signal from the Summing device to your monitors. One could feed a cue system, one could feed your MTC, and one could feed an AD converter in effort to print the stereo mix. This is not how I do it, but its just an example. You would either patch the master buss outputs, or the monitor outputs [which is also another way to directly patch a cue feed to another amplifier] into the SPL MTC, so that you are monitoring the result without trimming or attenuating the master buss. Now, perhaps the MTC is a great choice for you, but if all the features are not needed for your applications, than I would advise checking out the Coleman range of monitor controllers, and in particular the M3PH MK2. Its Everything you need and nothing you don't, with as little electronics in the path as possible.
