Author Topic: Wood flooring-good idea?  (Read 2458 times)
Bill_Urick
« on: November 30, 2008, 08:55:27 pm »
How important is wood flooring in a tracking area?
Is it that much better than carpet?
Good sense is, of all things among men, the most equally distributed; for everyone thinks himself so abundantly provided with it, that those even who are the most difficult to satisfy in everything else, do not usually desire a larger measure of this quality than they already possess.
andrebrito
Re: Wood flooring-good idea?
« Reply #1 on: November 30, 2008, 11:21:27 pm »
carpet = absortion at high frequencies placed over a large area
Acoustician and Musician
http://www.onlineacoustics.com - Projects and Products (RGP and Green Glue)
http://www.sonicflames.com - my crazy label
C.Cash
« Reply #2 on: December 01, 2008, 09:24:55 am »
I figure with wood floor you get the best of both worlds. You can always remove a rug, but carpet is permanent (well kinda).
Ethan Winer
« Reply #3 on: December 01, 2008, 11:12:41 am »
C.Cash wrote on Mon, 01 December 2008 09:24
Agreed, though when someone already has carpet I recommend buying a bunch of 2x4 foot Masonite or plywood panels at Home Depot. They're small and light enough to handle easily, and you can stack them against a wall or in a closet when not needed.
--Ethan
rankus
« Reply #4 on: December 01, 2008, 07:35:17 pm »
And don't confuse wood flooring with laminate flooring... one is wood, the other is plastic.
Bill_Urick
« Reply #5 on: December 02, 2008, 06:25:11 pm »
Ethan Winer wrote on Mon, 01 December 2008 11:12
--Ethan
Thanks all. This is what I'm going with.
For now...
C.Cash
« Reply #6 on: December 03, 2008, 09:40:36 am »
rankus wrote on Mon, 01 December 2008 18:35
Some laminate is actually wood composite and glue.
Tomas Danko
« Reply #7 on: December 03, 2008, 10:44:43 am »
C.Cash wrote on Wed, 03 December 2008 14:40
Wouldn't that be a kind of veneer then?
C.Cash
« Reply #8 on: December 03, 2008, 03:46:50 pm »
Laminate;
"Laminate flooring is actually a picture of wood attached to composite fiberboard, under a clear finish of melamine. It is considerably less expensive than hardwood and has more options for installation, including some that do not require glue"
Veneer;
"Wood veneer is a type of engineered wood that is made from very thin sheets of wood that are glued onto core panels (made from solid wood, MDF, or particleboard). The thin slices of wood are obtained by peeling the trunk of a tree or by cutting them from large rectangular blocks of wood."
finetuner
« Reply #9 on: December 09, 2008, 08:43:15 am »
Does anyone know if there is a difference between veneer floors and solid wooden floors regarding static discharge problems ?
I know laminate can cause problems (combined with low humidity).
Peter van't Riet
FineTune Mastering
lgreen
« Reply #10 on: December 23, 2008, 02:46:12 pm »
hello all,
I would say the wood flooring for sure. The acoustics will be so much better for you----not sure how many decibels of difference it can make for you though.
I guess you may have to do a sound test to check that out.
need any home renovation tips....flooring and carpet
