neilio wrote |
question, and i know a little about engines,as ive been a car fan all my life, isnt a supercharger actually better for everyday day driving for effiency, as the power band is available thorughout all rpm range? and as well no trouble with detonation, intercoolers, wastegates etc?
Well... Define 'Better'.
As for 'no trouble with wastegates, detonation, intercoolers etc', MOST superchargers are low-boost affairs, and they avoid intercoolers because they don't heat up the air very much, because they don't SQUASH it very much... likewise, they don't increase the tendency to detonate very much if they don't squash the air very much... so it sounds very much as though you're really only talking about LOW pressure superchargers.
Wastegates are a way of managing
excess pressure, and are the bain of upstream-metered-air systems, where DIVERTER VALVES are often used in their place. I think every supercharger system that I've seen recently has some kind of diverter valve, otherwise they'd be boosting at idle... and fuel economy would be utterly destroyed.
My supercharged VW has a diverter valve on it (although it differs in that it's there
exclusively to manage boost under LOW throttle-demand conditions), and neither of my Turbocharged cars has a wastegate or 'blowoff' valve: both are upstream-metered systems, so both use 'recycling' divert-valve technology, to keep the Mass airflow representative of the engine's air intake, and hence the amount of FUEL that it requires for a stoichiometrically-correct mixture.
..Certainly, it's inaccurate to say that a supercharger doesn't need an intercooler any more than a turbo does... the more you boost, the more you heat the charge by compression, the more you need an intercooler.
Also, there's more than one type of supercharger: the one most people think of is the Eaton/Rootes/Whipple blower, which is a POSITIVE DISPLACEMENT type: these DO produce boost at low revs -even at idle- and again I suspect that's what you are thinking of... the other type is the centrifugal supercharger, which produces rising boost with engine revs... Pros and cons for both of them I'm afraid: The positive displacement ones make boost as soon as you crack the throttle open, whereas the centrifugal ones don't. -This I suspect is what you're talking about with "range" of revs. -However, they DON'T tell you that at high revs this type runs out of puff in comparison to the centrifugal supercharger, which should probably out-blow a PD blower above 4,000 engine revs.
Two of my friends have identical C5 Vettes, both are supercharged, one with a PD blower from Magnusson, the other with a centrifugal blower. -Same engine, but the two Forced-induction systems make their characteristics QUITE different. One leaps off the line like a scalded cat, but runs out of puff at the top end, whereas the other is slightly more gentle (not that a 'Vette should ever be lacking in torque!) off the line, but
explodes as the revs build...
-Which is "better"? -I'm damned if I can tell you, but they're BOTH an absolute blast to drive!
neilio wrote |
i used to have an acura integra, and now the missus has a mazda 5 thingie(which we totally dig), both those cars could use a little more juice, and people always say well, you could turbocharge them, but id rather go supercharging as in everyday driving they are "better"(ambigious term , i know)...what say audio guy, particularily keith on this subject...why not supercharge instead?
When you say 'Mazda 5' do you mean the MX-5 Miata? -The Miata is a handling blast, and TONS of fun at Auto-Cross weeekends. -They make a "bolt-on" supercharger kit for at least the series one... -If you mean the SUV thingie, then I probably wouldn't juice the motor much, and even then not without first significantly upgrading the brakes and tyres... and probably equally significantly increasing the rear anti-sway rating... "More power" needs more control and the Mazda SUVs tend to have a reassuring sense of grip, although it disappears at the limit in a rather sudden fashion, instead of alerting you... -and that's a dangerous amount of mass high off the ground to take risks with...
The 'Teg might be a better candidate, but both are fairly high compression motors, so you probably coludn't go at ALL above 6PSI peak boost on 93 octane fuel. -That means that through most of the range you'd get 2-3 PSI, although that's a poorly-educated guess on my part, because the Integra is cammed to breathe and rev quite freely compared to say a VW motor.
Superchargers are a LOT less scary to fit aftermarket than turbos though... Turbos require oil for cooling, and some also ALSO need engine coolant to be pumped through a jacket around the lubrication path... along with some means of monitoring the temperature after shut-off, and an electric pump to FORCE the coolant through the jacket to prevent the bearings from caking up (these are commonly known as "wet" turbos).
Turbos are indeed more convoluted, but they do produce superior on-paper peak specs, and in hard performance terms are probably more 'capable'. PD superchargers are simpler to retrofit, but the gains are modest, and boost -no matter WHICH method you use to generate it- has to be LIMITED by fuel detonation characteristics and piston sweep/head volume compression ratio.
I've played with both and I've had lots of fun with both. If I ever convert another engine to forced-induction, it'll probably be an air-cooled Porsche with a dry-sump system... Just because I want to do it SO-OOO much!
Keith
