Author Topic: Rader PCM files for mastering  (Read 2547 times)
lucey
« on: June 18, 2004, 01:40:36 pm »
Is there a Radar playback workaround in Samplitude, Wavelab, PT le or the Masterlink?
I have some 88.2 files here from RecForums Tony at Oxide and I'm in the dark on playback.
I could ask him to convert but that would be an inconvenience, if there is another way.
Brian Lucey
Magic Garden Mastering
"the economy is a wholly owned subsidiary of the ecology" - unknown
lucey
Re: Rader PCM files for mastering
« Reply #1 on: June 18, 2004, 02:25:22 pm »
aah ... might be a Digigram VX card limitation.
now transferring files to ML with Alesis software
previously i had only seen 88.2 as Masterlink files.  looks like I need to invest in a new PC sound card ...
alright so occasionally i'm a computer idiot... ran it in PT Le with a 002
no problem .... done
Brian Lucey
bblackwood
« Reply #2 on: June 18, 2004, 09:49:21 pm »
Did the Alesis CD24 creation software work?
Brad Blackwood
euphonic masters
lucey
« Reply #3 on: June 22, 2004, 01:05:15 am »
bblackwood wrote on Fri, 18 June 2004 20:49
you know ... it didn't
it kept saying the .aiff file was incompatible, even though it looks for .aiff
so i loaded it in to Pro Tools 002 and went from there
Brian Lucey
mcsnare
« Reply #4 on: June 22, 2004, 08:12:12 am »
I always have to put SD II and sometimes AIFF files that I receive on disc , into my ProTools setup. Import to a session, then export as a WAV file and burn a new disc, before my PC will open it. Any software out there that will do this on my PC and allow me to open files on a CDR directly in Wavelab? Mac/PC compatibilty issues are a drag. I wish they wrote Samplitude for Mac.
Dave McNair
bblackwood
« Reply #5 on: June 22, 2004, 10:01:06 am »
Dave, if you buy something like MacDrive5 you can read Mac formatted discs directly from the PC, so all you have to do is copy them to your HDD and open them in something like WL. Since the SD2 is not a PC format, you still have to tell the software the bit depth and sampling frequency, but I do it here all the time, no issues...
Brad Blackwood
euphonic masters
jlapointe
« Reply #6 on: June 22, 2004, 06:30:07 pm »
mcsnare wrote on Tue, 22 June 2004 09:12
Try SD2Wav.  I think this is it here:
http://www.io.com/~mcgriffy/audio/
bblackwood
« Reply #7 on: June 22, 2004, 09:23:53 pm »
JLaPointe wrote on Tue, 22 June 2004 17:30
Try SD2Wav.
You still have to tell it what the bit depth and sampling frequency are...
Brad Blackwood
euphonic masters
Bob Olhsson
« Reply #8 on: June 22, 2004, 11:29:20 pm »
It's automatic if you use MacDrive and you aren't an idiot like me who always forgets to change the CD-R/DVD-R properties over to Mac format.
