Good morning Nika,,
you still do not get the point.
As Shannon's proof postulates that a bandlimited function cannot time-limited, and it is a prerequisite to feed the sampler with a bandlimited function, then it must be infinite for the sampling theorem to work.
As music is not infinite, it cannot be perfectly bandlimited and therefore does not apply to the prerequisite of the sampling theorem.
If you make music bandlimited it is not music anymore, as you made it oscillate into infinity.
You can put it this or that way. Either you get amplitude modulation if you sample too slow (and Fs/2 is much too slow) OR you treat the signal as if it was (suppose the original was) time-unlimited, and then you distort it with the ringing of your oversampling filter.
As I said earlier, when you sample so slow, you have to chose which distortion you want to have. You cannot eliminate both.
I totally sympathize with you in that you try to defend something that we have believed in for so long. But our believe was because we had no deeper insight into this area of mathematics.
It is perfectly obvious that Shannon's sampling theorem works for a infinite signal, like one or thousand sines you put together, okay, only if you have much time to look at that signal as his interpolation formula is an infinite sum.
But it is also intuitively obvious AND and outcome of his mathematical proof, that you cannot apply it to music, as the very time-limitness of a musical or speech signal violates the required bandlimit.
What more can I say ?
Charles
