Author Topic: My console..  (Read 5194 times)
Viitalahde
My console..
« on: June 11, 2004, 04:17:18 PM »
Hiya,
here's a couple of photos.. My console is all passive & unbalanced. It has four inputs: three of them are routable to the process path and two+1 (daw return) of them are to the monitor path. Process path has two 25k ladder attenuators (0.5db steps to -11db) and the first position takes them completely off the circuit. Monitor attenuator is a 10k ladder attenuator and the "mode" switch has two toggle switch where you can compose stereo, mono, L mono and R mono.
When listening to process path input, processors are NOT feeded with signal but the input is routed directly to monitors. When listening to DAW return, processors receive signal again. I wanted to avoid any parallel loads. Works for me!
I like this thing.. Great to use!
http://img78.photobucket.com/albums/v240/virtalahde/pmc1_1.jpg
http://img78.photobucket.com/albums/v240/virtalahde/pmc1_2.jpg
Then two shots of the little room I'm building. Still on progress but hopefully running later this year. Monitoring is Dynaudio BM6A's, and I really think I succeeded well with the monitoring&acoustics. Perfectly pleased for now! The rack is holding a Gyraf Audio G10 vari-mu compressor, a shelving Pultec imitation with Quad-8 CA27 gain make-up, and the console. An open Aphex Dominator 2 can be seen also, under mods, as also an RNC on the computer. The computer screen is around 1m behind the listening position - I like it better when I don't have to look at the screen while tweaking.
I'm building a Sontec MEP-250A clone with all discrete op-amps, also will have a M/S matrix and a passive splitter/summing unit.
But I started out with good monitoring and acoustics. ADC/DAC is LynxTWO-A for now. Still a beginner to mastering.
http://img78.photobucket.com/albums/v240/virtalahde/rakki2.jpg
http://img78.photobucket.com/albums/v240/virtalahde/rakki1_1.jpg
Jaakko Viitalähde
http://www.virtalahde.com
bblackwood
Re: My console..
« Reply #1 on: June 11, 2004, 05:13:16 PM »
Looks sweet!
Have you measured the crosstalk in the box? Frequency response?
How's that pultec imitation?
Brad Blackwood
euphonic masters
Viitalahde
Re: My console..
« Reply #2 on: June 12, 2004, 04:31:45 AM »
No I haven't.. Will do.
The Pultec thingy is just great. After I got my monitoring right, I found out I didn't like the input trafo - so I removed it. It now has only output trafo (Jensen) and it's there just for the sound. This thing really sings! I love it! It's a real sound-digging tool, you can bend bass out of anything. Very pure sounding.
Jaakko Viitalähde
davidc
Re: My console..
« Reply #3 on: June 12, 2004, 05:21:21 AM »
Jaakko,
If that gear in the photo is home built, then Ive got to say you have done a fantastic job, and I'm envious. My home built projects always look home built Embarassed
Can I ask where you got the circuits from?
Best Regards
David C
Viitalahde
Re: My console..
« Reply #4 on: June 12, 2004, 05:53:08 AM »
Well,
the Gyraf Audio G10 is a commercial circuit, the designer Jakob Erland & I had a prototype thing going on so it's a result of that.. G10 review is here: http://www.gyraf.dk/g10/g10_review.jpg
The console is my own design.. And the Pultec EQ is a variation of the old Pultec, also can be found at Gyraf Audio, under DIY projects.
You should join us at "The Lab" - there's a bunch of people who do this all the time! Great minds and most of them do better work than me!  Laughing Forum:
http://www.prodigy-pro.com/forum/index.php
Jaakko Viitalähde
davidc
Re: My console..
« Reply #5 on: June 12, 2004, 06:20:46 PM »
Thanks Jaakko, looks an interesting site.
David
dcollins
Re: My console..
« Reply #6 on: June 14, 2004, 04:09:07 AM »
Viitalahde wrote on Sat, 12 June 2004 01:31
What are you using for the interstage trafo?
DC
Viitalahde
Re: My console..
« Reply #7 on: June 14, 2004, 04:29:56 AM »
No interstage trafo. Just the passive circuit, seeing a 15k load at the Quad 8 amp input.
The Gyraf variation of the Pultec is done like this, except that the amp is tubed (SRPP). Now I feel it gives just the right amount of goodies, and it's not a one-trick pony. I am actually pretty sure this thing will follow me through my life.
Jaakko Viitalähde
OTR-jkl
Re: My console..
« Reply #8 on: June 16, 2004, 02:13:08 PM »
Nice work.
How'd you do the face plates...?
J Lowes · OTR Mastering
Professional Audio Production for Life
www.ShoutLife.com/OTRMastering
dcollins
Re: My console..
« Reply #9 on: June 17, 2004, 04:27:41 AM »
Then is it fair to call it a "Pultec?"  How about an LC equalizer with tubes?  What mu in the toroids?
There's a reason it's famous, you know.
DC
Viitalahde
Re: My console..
« Reply #10 on: June 17, 2004, 06:01:10 AM »
Dave, You're probably right.
It doesn't even have inductors - caps only. Shelving EQ. So it's even more far away from Pultec.. Just an adaptation of the classic Western Electric circuit.
Haven't really thought of that. On the front plate I have: PEQ-8A, which stands for "passive equalizer (with) quad 8 amplifier"
OTR-jkl:
Front plates are actually just done with a Dymo-something writer. Black text on a transparent sheet.. So the sheet is visible when you look at it, but I don't really care. As long as the thing sounds good & works well, I don't care too much about cosmetics as long as things aren't butt-ugly. Nice colours are one thing I try to implement in my gear.
Jaakko Viitalähde
Page created in 0.019 seconds with 20 queries.
