Pages: 1 [2] 3 4 5   Go Down
Author Topic: The Apogee Converter thread. 16x unit care and feeding.  (Read 21281 times)
tom eaton
Re: The Apogee Converter thread. 16x unit care and feeding.
« Reply #15 on: October 06, 2008, 04:23:19 pm »
I don't think TotalMix can run across different PCI cards... so it would seem that unless I go MADI the RME system won't really do what I want, which is 32 ins and outs at 96kHz route-able one to one input to output.
I do have the MOTU 424 card, and strange as it seems, that may be the ONLY way to do what I want.  The card actually would support 48 inputs and outputs at 96k through one instance of MOTU's CueMix software.
And yes, entire system clocked externally to an Isochrone.
The things you discover!
t
Tomas Danko
« Reply #16 on: October 07, 2008, 07:37:10 am »
There are RME solutions where you can get lots of channels and it all merges inside one single TotalMix.
However, since you've already got the MOTU 424 I'd suggest going that route. It will hopefully do what you need it to do, it will cost less, and you're already familiar with it.
tom eaton
« Reply #17 on: October 07, 2008, 09:14:15 am »
Tomas Danko wrote on Tue, 07 October 2008 07:37
For the record, are you talking about MADI?
I did consider that route.
tom
Tomas Danko
« Reply #18 on: October 08, 2008, 10:15:48 am »
tom eaton wrote on Tue, 07 October 2008 14:14
tom
Yes, MADI will give you the highest channel count among the RME products.
Andres Gonzalez
« Reply #19 on: October 24, 2008, 07:06:37 pm »
This is perhaps a bit out-of-place in an Apogee 16x care and feeding thread--but I wanted to relate my experience with Apogee support because that is pertinent to this thread.
I upgraded from PT HD 7.1 to 7.4 because I had a project come in that was a 7.4 session and my rig would not read it properly (they did not render some elastic time tracks). Consequently, I needed to upgrade PT to 7.4.
After 7.4 was installed, PT would not recognize my Rosetta 800 and my AD-16X. Turns out that the X-HD cards in the converters needed the firmware updated also to work with PT 7.4.  So, I tried to update the firmware as per Apogee's normal process (downloading a new firmware image to the X-HD cards via MIDI) but had nothing but problems--nothing seemed to work.
So, I called Apogee support and they said just send in the X-HD cards. I sent them in, and they updated the firmware in both cards, and sent them back to me WITHIN ONE DAY, sent them back FedEx NEXT DAY AIR, NO ADDITIONAL CHARGE TO ME, and I was back in business.
I must say, Apogee support is great. The support engineers were knowledgeable, friendly, easy to work with, and their turn around time wonderful. Needless to say, I will buy from Apogee again.
-Andres
J.J. Blair
« Reply #20 on: October 28, 2008, 01:03:27 pm »
Apogee does indeed have first rate support.  That's part of why I've been buying their products for 14 years,
studio info
bushwick
« Reply #21 on: October 29, 2008, 02:40:26 pm »
I've just recently made the berg switch inside the units as I couldn't get some of them to come on. I kinda of like the ease of one switch flip turning everything on or off.
j
Joshua Kessler
bushwick  studio
brooklyn, ny
www.bushwickstudio.com
tom eaton
« Reply #22 on: January 31, 2009, 08:48:24 am »
Another thread about integrating the 16x units with RME cards:
http://recforums.prosoundweb.com/index.php/t/26716/2571/
Trying to keep this thread up to date!
Phil Mayor
« Reply #23 on: January 31, 2009, 05:38:12 pm »
ha..just spotted this thread. I have the dreaded DA/AD16x switch problem too.. Confused
tom eaton
« Reply #24 on: March 05, 2009, 07:51:04 pm »
Windows will no longer be supported as of 2009.
http://www.eqmag.com/article/apogee-discontinues-windows/feb -09/93403
Nice.
marcel
« Reply #25 on: March 06, 2009, 11:22:54 am »
My 192k Rosetta 800 has started to develop the dreaded switch problem, too.
Best, Marcel
compasspnt
« Reply #26 on: March 06, 2009, 11:55:59 am »
If one is going to change the internal jumper so that the units power on at mains application...
Is this something in the manual, or is there a special technique, or extraordinary knowledge required?
Edit: Thanks Tom!
tom eaton
« Reply #27 on: March 06, 2009, 12:11:56 pm »
It's in the manual, not tricky at all.
t
rankus
« Reply #28 on: March 06, 2009, 01:53:36 pm »
compasspnt wrote on Fri, 06 March 2009 08:55
Yes,  Page 13 of the manual.  It's a simple computer style jumper that is popped off and placed back on the adjacent pins. It is about center of the motherboard... I think its the only jumper on there... I just did mine a couple of weeks ago and it works great.
compasspnt
« Reply #29 on: March 06, 2009, 02:11:38 pm »
Excellent.
Now I just need some of those silly metric screws!
Pages: 1 [2] 3 4 5   Go Up
