Pages: 1 [2] 3 4   Go Down
Author Topic: T-USA U47M (Modified by J.J. Blair)  (Read 18678 times)
J.J. Blair
Re: T-USA U47M (Modified by J.J. Blair)
« Reply #15 on: September 09, 2008, 10:55:55 am »
Jack, well, I can't agree with your tech on the cost, as I used about $100 in parts.
The capsule that was in Barry's mic was a new Neumann K47.  This would be the first I've heard of them using reskinned K47s.
And as far as the capsules that Robert Crash sells, they are reskinned by Siegfried Thiersch.
studio info
seedyunderbelly.com
« Reply #16 on: September 09, 2008, 12:45:03 pm »
Hi JJ
How did it compare with a real U47?
-j
J.J. Blair
« Reply #17 on: September 09, 2008, 02:22:34 pm »
seedyunderbelly.com wrote on Tue, 09 September 2008 09:45
Hi JJ
-j
John, I have an original U47, serviced by Bill Bradley, which is a really great sounding example of a 47.  I've A/B'd against other vintage 47s as well as new clones, and it always stood up with the vintage ones, and was always better than the clones.  It's not one of the magical 47s, but it's a really good one.
When I got Barry's mic, I preferred mine to his.  However, when I was done with Barry's mic, I liked the sound of it better than my 47.  I'd been waiting for this one record to get finished, so I can do all the same things to my mic that I did to Barry's.  We keep having to go back and grab vocals in spots on songs, so I'd been leaving it in order to keep the tone consistent.
That record is finished though, so it will probably happen this week, as soon as I get my M49s off my bench.
Bill had done some things I find curious, such as increasing the voltage on the PSU, and using a 2.2
studio info
Tricatel
« Reply #18 on: September 09, 2008, 02:41:16 pm »
Hello JJ,
I do not exactly recall the list, but from what I remember.
Wrong plastic connector (fits but creates noise over while)
Wrong (low impedance) plastic used for all components.
Wrong connector blades.
Wrong tube socket.
No heat sink resistor.
Wrong PSU.
Wrong surface plating (nickel will stain with time)
Mostly wrong everything.
It is hard to believe that the cost for the update parts is less than $100 and I do not want to think about the work cost.
In any way only a Neumann is a real 47!!!
Jack
Barry Hufker
« Reply #19 on: September 09, 2008, 06:23:48 pm »
J
J.J. Blair
« Reply #20 on: September 09, 2008, 07:10:37 pm »
Jack, T-USA is not longer using the FLEA bodies.  I believe the new ones are currently made in China, but the connectors on this mic were fine.
That non heat sinked drop resistor was a major issue that I posted about already, and as I said, I think they are changing it as a result of my making a stink about it.
studio info
wwittman
« Reply #21 on: September 10, 2008, 02:44:20 am »
wwittman wrote on Sun, 07 September 2008 18:35
out of curiosity,
between the original Telefunken US mic and its upgrades, plus the costs of the mods JJ did... what's the TOTAL cost of the mic?
William Wittman
Producer/Engineer
Tricatel
« Reply #22 on: September 10, 2008, 09:11:01 am »
Hello JJ,
please check out Mr. Thiersch webpage, he worked as a development engineer at Gefell.
http://www.thiersch-mic.de/stm_geschichte.html
However, his skinning work leaves much to be desired for.
The M7s he does either PVC or Polyester suck compared to original Berlin or Gefell.
The 87 capsule he did for me was not useable at all, a 54 he did was O.K. at least for the price.
Here is a quote of the Telewackers web-page:
Telefunken USA's Platinum Series microphones are the award winning, historically correct replicas of the originals. Each microphone system represents a meticulous reverse engineering of the original classic equipment. Hand Built and assembled in the USA.
So were is the made in China fits into all that?
Jack
MI
« Reply #23 on: September 10, 2008, 09:47:16 am »
wwittman wrote on Wed, 10 September 2008 02:44
out of curiosity,
J.J. Blair wrote on Tue, 09 September 2008 10:55
So $100 in parts...but figure a few hours labour? If you had to hire a tech to do it figure at least $75 / hour?
J.J., can you please advise where you bought the parts?
Barry, is it not the V series you bought? The M is EF14 tube.
$9,995 VF14 -  http://www.telefunkenusa.com/products/show_product.php?item= 7&cat=mics
$6,995 EF14 -  http://www.telefunkenusa.com/products/show_product.php?item= 12&cat=mics
Has anyone tried their new VF14 tube?
MI
J.J. Blair
« Reply #24 on: September 10, 2008, 10:20:58 am »
Jack, thanks for the correction regarding Thiersch.
Regarding Barry's mic, it was a U47-M, but it did indeed have a VF14.  It was not marked with a "V."  IIRC, the plate said "U47-M serial no. 0087."
I've criticized T-USA many times for the use of the phrase "historically correct."  But it's not like the FTC is going to sue them for misleading advertising or anything, so...
studio info
Jørn Bonne
« Reply #25 on: September 11, 2008, 05:42:07 am »
Barry Hufker wrote on Wed, 10 September 2008 00:23
J
Jørn Bonne
« Reply #26 on: September 11, 2008, 05:52:39 am »
Hi JJ
Been following your U47 investigations and try-outs with great interst. Good work.
Would you care to name the resistors and capacitors you ended up using in Barry's mic? Brand, type and value in the respective positions.
Did you closely follow the values in one of the known U47 schematics or did you deviate in some positions to get a particular performance?
Would be much appreciated!
Thanks
JB
J.J. Blair
« Reply #27 on: September 11, 2008, 09:43:38 am »
I used all  carbon comp resistors on the ladder, in the same values prescribed in the schematics.  A couple different brands.  The capsule bias resistor and grid shunt resistor were 100MΩ and 200MΩ respectively, and I used NOS carbon spiral resistors made by TRW.  I used NOS, military issue, paper in oil caps in the C3 and coupling cap position, both at 1
studio info
Jørn Bonne
« Reply #28 on: September 12, 2008, 12:02:01 pm »
Good one! Thanks.
What brands of carbon comps do you recommend?
What's a good source for the NOS paper in oil caps?
JB
J.J. Blair
« Reply #29 on: September 13, 2008, 02:33:23 am »
You can do one stop shopping at surplussales.com.  They have NOS Allen Bradley carbon comp resistors.  You may or may not prefer them to carbon film or metal film.  The originals were not carbon comps.  The metal film are supposed to be quieter, but the sonic signature of carbon is more in line with the vintage mics, from what the various design gurus have told me.
They have high quality JAN paper in oil caps by West Cap, in 1
studio info
Pages: 1 [2] 3 4   Go Up
