grant richard wrote on Tue, 02 September 2008 17:23 |
So you can hear all those frequencies at 48k!!!!
More importantly, can your converters analog input stage hear up to 48K and is its transient response good enough to capture all the overtones that are produced in and above the human hearing range?....
I think Human hearing is also about perception, and I think with higher sampling rates, it only makes sense that there are more puzzle pieces snapped into place. Conversion is a FINITE process vs Air & Time [INFINITE] which is converted to electrical VOLTAGE [Amplitude] and PITCH [Frequency] which is also INFINITE and the carries along at the speed of light.
A smooth moving wave form becomes a randomized step ladder when its digitally encoded. So the laws of common thinking dictate that we will notice a higher resolution of captured frequency content. So, the clocking, the analog stage, the power supply, the DSP filtering, all of these things matter to the converters response, but I assure you, if your recording a new version of GiGi Allen, then there's no point in recoding 96K.
There is a TON of stuff I would never record WITHOUT being in 96K, and there is a TON of stuff I would NEVER switch the converter higher than 44.1K. Some converters won't sound different in 96k, they'll sound worse.
