In artistic and technical terms, dynamics are preferable for singers who scream for multiple reasons, one of them is the abuse the diaphragm gets subjected to, another one is a slight smoothing of the transients which leads to a more controlled sound, another reason is that generally speaking dynamic mics that have been optimized for kick drum applications tend to cut a lot of the most offending frequencies from a screamer.
And those are also reasons why most condensers are unsuitable for recording screamers... first is the issue of SPL handling (And fragility), second is the issue of moisture getting trapped in the mic (All the screamers I have recorded tend to spit an awful lot, more than what a pop filter or a windscreen will be able to cope with), then is the issue of frequency hyping, the problem being that the frequencies that get hyped tend to be around the same frequencies where the screamer's voice starts to break.
Funny enough, I've done my share of growlers and low pitch screamers in my death metal days, and for those applications I'm ambivalent, a good dynamic can help you tame and overly throaty singer but a good condenser will raise the singer in the mix, provided that he/she (And yes I mean she, take Angela Gossow as an example) has good volume control.
Hope this is helpful.
BTW, Possible candidates include the Audix D6, AKG D112 and EV RE20... some unlikely candidates that sound good include the older Shure Unydine mics, Soundelux U195 and the U47-fet.
