Barry Hufker wrote on Sun, 29 June 2008 15:21 |
I understand what you're saying -- noise is everywhere and there's no escaping it. But I would also take that to mean if we can reduce the noise inherent in a system then the spikes in A/D converters will be lower (for instance if we can ever get true 20 to 24 dB conversion. The noise will be there only much lower than at present.
I suppose one last statement would be what I said earlier, I'm surprised digital systems aren't currently less noisy than I was naive enough to believe.
I am not the converter expert here, but that hasn't shut me up so far.
I'm not sure I would characterize the peak value of the noise as spikes. The random noise, sometimes lines up and most times doesn't.
FWIW there is usable signal reproduction below this apparent noise floor, just like you can hear signal down in the residual noise of magnetic tape, you can hear signal below this converter noise.
More is always better, right? I'm sure there are engineers working feverishly to be the best on paper, to better land the "price is no object" customers. OTOH I saw 24b codecs offered by a Chinese fab for $0.90 in quantity (Cool Audio).
I'm not sure it matters much in the context of typical audio signals we are called on to process or reproduce. As long as the channel poo is 10+ dB below the signal poo... and random, no worries.
