Pages: 1 2 [3] 4 5   Go Down
Author Topic: Sonoris (Linear Phase) Equalizer released  (Read 21841 times)
duckhunter
Re: Sonoris (Linear Phase) Equalizer released
« Reply #30 on: June 17, 2008, 01:14:30 PM »
This is why I can't talk to my two daughters who are engineers about their studies and work.  I tried to review my daughter's thesis and had to put it down after three pages because I couldn't understand a thing.
Studio 89
Andrew Hamilton
« Reply #31 on: June 19, 2008, 02:55:23 AM »
I'm glad that we're getting to talk about IIR and FIR.  I thought I read long ago a post that Daniel Weiss wrote in which he explained that his linear phase eq was the only one out at the time which was FIR.  I believe that he stated that FIR is best (most transparent?) for linear phase eq.  There was an early Arboretum plugin called Ionizer which was linear phase (128 bands), but I believe that it uses IIR filtering.  Bruno, or DC, can you please clarify this recollection, and, if true, are there any _minimum phase_  eq'z that use FIR?
Andrew
www.serifsound.com
premastering for CD and DVD-A.  Featuring FTP load in and delivery as well as analog tape transfers.
bruno putzeys
« Reply #32 on: June 19, 2008, 03:19:32 AM »
Andrew Hamilton wrote on Thu, 19 June 2008 08:55
I wouldn't see the point. Although minimum phase does not imply IIR, all normal audio EQ functions are IIR in nature so a FIR filter could only approximate those. That would further go at the expense of lots more processing power. The only advantage I could think of is that no rounding errors are fed back. With double or extended precision processing that shouldn't be an issue anyway.
cerberus
« Reply #33 on: June 19, 2008, 12:33:25 PM »
thanks bruno for that eye and ear opening explanation.  the math may confound
us, but imo the priniciples you've outlined are basic and should be
understandable, even to a math idiot like myself.
but myths persist because people like them. so i hope you will repeat
the information again here whenever you notice someone
assuming a wrong idea about filter design. as we all
know, certain brands of eq are revered among
the top m.e.s. but we rarely talk about why.
it helps me that i spent time carefully selecting cutoff and q  numbers for
[izotope's adjustable] src. the parameter entry allows variations up to
four decimal places, but most eq faceplates don't get
that specific.  i heard significant differences in
character from changing these numbers
very slightly. so a q of 1.000 and
1.002 could sound different...
but if one were designing an eq,
it would seem logical to
label that setting
simply as: "1.0".
jeff dinces
Matt_G
« Reply #34 on: June 27, 2008, 03:15:46 AM »
Getting back on topic, I've been using the Sonoris LP EQ v2.1a as an FX Pansion wrapped RTAS plugin in Pro Tools HD & unfortunately it's very buggy Sad If you type in the parameters it often crashes Pro Tools to the finder. If you close the GUI window while it's playing back it goes into a playback loop & than crashes Pro Tools.  The latency is insane over 66000 samples! The only way I can use it stably is to manually dial in the parameters I want while Pro Tools is stopped, close the GUI (pray) & then hit play. It works fine in this way. It does sound good though, just a pity it is almost unusable in a practical way.
Now in Sonoris' defense this is a VST plug-in & wasn't tested for stability as a wrapped plug-in in the Pro Tools environment. But usually I don't have any problems with wrapped plug-ins.
I'll post this to Sonoris tech support as well.
Sigh...
Matt
Matthew Gray Mastering
Brisbane Australia
Matt_G
« Reply #35 on: June 27, 2008, 10:15:44 AM »
Wow how's that for service, I emailed Pieter & he has already given me a download link to 2.1b which has fixed one of the problems (GUI closing crash). He is looking into the other issue & maybe considering RTAS support in a future release. Impressive...
Matt
Brisbane Australia
cass anawaty
« Reply #36 on: June 27, 2008, 11:13:21 AM »
Yes--the update improved things here also.
What's with the gain in bypass?  Can someone explain why this happens--i.e. is it a function of the design?
I'm happy to have it--thanks for the rec, Steve.
Cass Anawaty, Chief Engineer
Sunbreak Music, LLC
High Resolution Stereo Mastering
www.sunbreakmusic.com
TotalSonic
« Reply #37 on: June 27, 2008, 12:13:54 PM »
Cass Anawaty wrote on Fri, 27 June 2008 11:13
There's no gain when the plugin is in bypass in the SAWStudio version - don't know about the VST though - what host are you using?
Best regards,
Steve Berson
cass anawaty
« Reply #38 on: June 27, 2008, 02:42:51 PM »
TotalSonic wrote on Fri, 27 June 2008 17:13
Best regards,
Steve Berson
Sequoia.  I wasn't sure if the upsampling was causing the "overs".  It's not anything like a couple of db--less than that, but noticeable.
Sunbreak Music, LLC
PieterS
« Reply #39 on: June 27, 2008, 03:21:08 PM »
Cass Anawaty wrote on Fri, 27 June 2008 20:42
The bypass is a soft bypass, meaning that upsampling is still functioning. This is to prevent shifts due to the latency.
The upsampling can cause overs, that's probably what is going on.
Sonoris Audio Engineering
www.sonorissoftware.com
cass anawaty
« Reply #40 on: June 27, 2008, 03:52:03 PM »
PieterS wrote on Fri, 27 June 2008 20:21
That explains it--thanks Pieter.  I'm really enjoying have this.
Sunbreak Music, LLC
Matt_G
« Reply #41 on: June 27, 2008, 08:40:55 PM »
PieterS wrote on Sat, 28 June 2008 05:21
If you're operating at 96kHz as the native sample rate does the EQ do any resampling?
Matt
Brisbane Australia
PieterS
« Reply #42 on: June 28, 2008, 07:18:46 AM »
Matt_G wrote on Sat, 28 June 2008 02:40
Matt
No, upsampling is only enabled for samplerates below 50KHz
PieterS
« Reply #43 on: June 28, 2008, 06:27:52 PM »
Matt_G wrote on Fri, 27 June 2008 16:15
The update is now available for the demo and full versions of the Sonoris (LP) Equalizer at http://www.sonoris.nl/catalog
Andrew Hamilton
« Reply #44 on: June 29, 2008, 07:08:53 AM »
Andrew Hamilton wrote on Thu, 19 June 2008 02:55
...I thought I read long ago a post that Daniel Weiss wrote in which he explained that his linear phase eq was the only one out at the time which was FIR.
Andrew
Well, after reading the .pdf for the Weiss lin ph eq, I gather that not only does he use IIR, just like Sonoris, but also does the same time-travel front-back thing for lin ph.   (So much for _my_ memory.)
Andrew     Rolling Eyes
www.serifsound.com
Pages: 1 2 [3] 4 5   Go Up
Page created in 0.094 seconds with 20 queries.
