Author Topic: Tell me this is ridiculous  (Read 7405 times)
natpub
« on: May 31, 2004, 03:28:31 AM »
I read this quote on a thead at another site:
"...FWIW: A mastering engineer I usually master with has abandoned using his L2 almost entirely and finds that just turning it up and letting the inputs to the AD clip, sounds better 90% of the time..."
It seems to me that would be like taking scissors and cutting off the top of all the music and replacing it wish harsh digital distortion?
Kurt Thompson
Vibrational Arts, Inc.
Blue Skyway Music
Sonic Sorcery Studios
Austin,TX/Columbus,OH
jfrigo
Re: Tell me this is rediculous
« Reply #1 on: May 31, 2004, 03:50:38 AM »
natpub wrote on Mon, 31 May 2004 00:28
I've had a couple clients who like to just push up the master fader into the red in their pro tools rig rather than use a limiter. They like digital clipping better than analog clipping, though a bit of that seems attractive to some as well, especially in the form of some of the simple "soft limit" or "soft clip" circuits in certain A/Ds. I've also had a couple that liked this pro tools clipping approach in Sonic. I know several NYC guys (and others I'm sure) have done this on certain sessions for years. Back when a plant would bounce back a pre-master for overs, they'd reduce the master fader in Sonic by .1 dB and clip the channel faders. That way you get the clipping but never produce an over and the master doesn't get rejected. These days clipped masters are pretty much standard in some circles and plants no longer complain. I think often they don't even read the PQ log anymore.
natpub
« Reply #2 on: May 31, 2004, 04:21:33 AM »
I think I see, but isn't that just going to get you a flat top across the whole thing, with a fakey digital sounding haze around it? It seems worse to me than hyper-compression. Or am I missing the boat here? I don't know mastering, so am curious.
Thanks,
--KT
Kurt Thompson
Blue Skyway Music
Ed Littman
« Reply #3 on: May 31, 2004, 11:18:25 AM »
On a few projects I've clipped the converters to the point of not needing the l2. It can give the music the sizzle & level that the client wants.
Ed
Jason Poff
« Reply #4 on: May 31, 2004, 12:26:39 PM »
I believe very short clips (don't remember the exact length just a few samples?) are inaudible. Might be useful on a master with alot of transients.
Jason
jfrigo
« Reply #5 on: May 31, 2004, 02:39:40 PM »
natpub wrote on Mon, 31 May 2004 01:21
You are right that in general this is a "bad" thing, but if the client loves it and leaves happy, it can't be all bad. I certainly try to avoid clipping and the resultant distortion when possible, but if that's what the job demands, I'm not too cool to light a couple red lights. However, I would not use this approach as standard.
Most people use the term "hypercompression" to encompass too much compression, too much limiting, or clipping. It's the abuse of dynamic range reduction by whichever method, so this intentional clipping can be thought of as one manifestation of the "hypercompression" problem.
bblackwood
« Reply #6 on: June 01, 2004, 11:19:43 AM »
Yah, clipping is commonplace in the quest for level. I don't think Tarnished Sound even owns any limiters...
I also think you'll find that if you are gonna clip the signal, doing it after is digitzed will yield better results than hammering the ADC.
Brad Blackwood
euphonic masters
j.hall
« Reply #7 on: June 01, 2004, 02:23:45 PM »
jfrigo wrote on Mon, 31 May 2004 02:50
not sure about HD, but mix plus systems make your statement redundant
the mix buss essentially was a brick wall limiter.  you really couldn't get any digital clipping at the 2 buss
it just got more and more squashed as you hit red.
jfrigo
« Reply #8 on: June 01, 2004, 05:43:23 PM »
j.hall wrote on Tue, 01 June 2004 11:23
You don't think what a master fader in PT mix did when it hit red was clipping? It sure looks and sounds like clipping to me. Are you saying that a Mix system wouldn't put out full scale? I thought it would, but even if it didn't, it sure the heck can still clip. It's a brick wall clipper like any other digital gain device turned up beyond it's headroom, not a brick wall limiter, as far as I can tell.
Skwaidu
Re: Tell me this is ridiculous
« Reply #9 on: June 03, 2004, 12:57:37 PM »
I have a producer/mixer friend here who swears by clipping the ADC...
He very much prefers it for at least beat-heavy stuff.
He did me a demo with a L2 and some smashed converters on a club-style track and I have to agree that he has a point...
"You Gotta Love The HOMO Stuff!"
http://koti.mbnet.fi/skwaidu/Homomilk.jpg
http://www.backtoback.cd/TIB3.jpg
Bob Schwenkler
« Reply #10 on: June 04, 2004, 07:21:28 PM »
i dont get it. i was talking to the guy who was asking about this in what i think is the thread that was referred to. we cant be talking about clipping very much... just on transients? what does clipping converters do that a limiter wont do more gracefully?
bblackwood
« Reply #11 on: June 04, 2004, 08:04:39 PM »
chikkenguy wrote on Fri, 04 June 2004 18:21
Clipping allows the transient of the waveform to remain intact until 0dBfs - a limiter will start to roll that off as it approaches full scale. This can be felt as a reduction in 'impact' especially, but the diff is usually only apparent at larger levels of GR...
Brad Blackwood
euphonic masters
Level
« Reply #12 on: June 04, 2004, 09:13:28 PM »
Yep..I do find it rediculous...but case in point..my Artist this week wants his R&B album to be as "loud as R. Kelly"
If you push L-1+ or L-2 up, the mids come up to overbearing and the highs get cloudy. The bottom gives way to "blasting"
To solve this "problem", I have one stand alone CD recorder where I can hit its analog inputs pretty hard and the circuity compresses without the large change in powerband response. It has a rather soft limiter and easy knee compression "sound" that will give him the goods.
That damned thing will actually get a +18VU if I need it.
I feel it is high time for the standards to be limited to RMS of -17..but it is all music dependant. His R&B album will end up around -12RMS ...although it WILL sound better at -17RMS.
R. Kelly sells, he wants to do the same.
I do not like the trend...but clients wishes prevail...unfortunantly.
http://balancedmastering.com
"Listen and Learn"
---Since 1975---
Ronny
« Reply #13 on: June 05, 2004, 02:45:03 AM »
bblackwood wrote on Fri, 04 June 2004 20:04
Two kinds of clipping here at issue and I wouldn't want chikkenguy to get the wrong idea. The clipping that Brad is talking about, "I think", is flat topping the waveform before it exceeds -0dBFS. There is no distortion just reduced peaks. Digital clipping of the converter is when the signal exceeds -0dBFS. To my knowledge a digital limiter will not roll off when it's printed, it will limit exactly where the threshold is set, if it's a hard knee it's instantaneous brickwall, as soon as the first sample exceeds the threshold. To flat top the waveform at the ADC I always thought took limiting the mic pre, how else do you clip an ADC without exceeding -0dBFS? If you exceed -0dBFS you run the risk of the worst clipping distortion of all time, digital distortion when the signal exceeds -0 and the system no longer interprets it as music. At 24 bit risking overs at the ADC is a needless worry, IMHO, just bring the gain down and make it up later where you can denoise any noise floor lost, if you feel the need. One poster mentioned digitally clipping quick transients. While it's true that fast transients that exceed -0dBFS can be inaudible to some ears, if the signal lasts only a few milliseconds over, the audio is gone just the same. If you exceed the limit too long you get digital burps that sound terrible and can ruin a take, but clipping quick transients although inaudible as individual transients because they are short, form a blanket over the sound that is quite noticeable to my ears, "if" too many transients are clipped in a row over short timeline. It's a fuzzy distortion that renders the audio degraded in my opinion. I'm sure some people perceive it as squash distortion, but it's quite different. There are better ways these days than clipping the waveform to a distortion level, staged limiting with automated release control, will get you just as hot and without the blanket on the sound that clipping quick transients results in. IN MY HUMBLE OPINION!  Very Happy
bblackwood
« Reply #14 on: June 05, 2004, 08:00:29 AM »
Ronny, we are essentially discussing using 0dBfs as a 'limiter', clipping anything that attempts to go beyond it such as driving the input of the ADC or some stage after sampling. In some cases it works better than just limiting. Some guys rely completely on clipping for level.
Brad Blackwood
euphonic masters
Page created in 0.078 seconds with 22 queries.
