Berolzheimer wrote on Wed, 23 April 2008 12:14 |
It's a little cumbersome in PT actually- I find I have to record back into a track ( I know it's controversial but in the listening tests I've done the BTD function just didn't sound as good), either with a dither on on the master fader or then process the recorded mix with an AS dither, so then I have a 24 bit mix with 16 bits of information & 8 bits of zeroes, & then export that as a 16 bit interleaved file.
This is incorrect. Dither does not add 0's. Your mix on the new track is still a 24bit signal with 24 bits of resolution, not 16 with eight 0's on the bottom. BUT!!! You added dither noise (which is a type of "hiss") to the signal. That's the only difference at this point. The mix has slightly more noise in it.
When you convert to 16bit, the software simply discards the bottom 8 bits of the 24bit wordlength, which makes the exported file 16bit. The dither noise you added in the previous step THEN helps smooth out the distortion that is caused by chopping off the bottom 8 bits.
Also, just for those who don't know, I should probably point out that there are different types of dither for different applications. Certain types of dither you never want to "double up" or do more than once. Those are usually the Noise Shaped dither. Only put that in the audio as you are printing your master which will be directly converted to 16 bit.
Dither without noise shaping is the type of dither that the digi mixer applies to the inserts and busses. That type of dither is ok to add on top of itself.
