ajmogis wrote |
These are the phantom powered variety.
They're
ALL phantom powered... -even the electret ones.
ajmogis wrote |
I'm suspecting they may be pulling some large transient current.
Impossible. They're fed through 6.8k resistors. even if they went DEAD-SHORT CIRCUIT, they couldn't
possibly pull more than 7 milliamps per leg. Dig out your console schematics and confirm that the mics are fed with 6.8kΩ resistances from the 48V rail... or another way to check would be to meter the voltage between pin 1 and pin 2 with nothing connected. -It should be 48V of course. If you then connect a 6.8kΩ resistance between pins 1 and 2 and measure again, it should drop to 24V. -Given that these are confirmed by actual measurement, it would be completely inconceivable for any microphone to reasonably draw more than about 10mA... at 14mA (the absolute maximum current drawn by a dead-short on BOTH legs) the mic would be dead because while current would be at maximum, voltage would be at minimum...
Perform the 6.8kΩ resistor measurement test on your console outputs AND your external preamp outputs, if they agree, you're barking up the wrong tree.
-Has it been more humid when these instances have occurred, (is one question which springs to mind) -and were these difference in behaviour with different preamps noted within minutes of each other, or on different days...?
...the clue may be in the details.
Keith
