Author Topic: monitor placement advice  (Read 4917 times)
lostinthewires
« on: March 28, 2008, 01:45:58 PM »
Hi ,
I'm looking for suggestions for the placement of my Alesis m1 mk2 monitors.
My living/studio room is L 23' W 15' H 8' ; has rockwool bale basstraps in each corner and I have made six 2'x4' rfz absorbers.(4" rockwool)
The Alesis manual suggests around 3' per side equilateral triangle placement but I was wondering if I should go wider since I have a bit more space.
Right now they are at 3' and 38% back from front wall, and having read Ethan's piece are off the room center point. L is 4 1/3' from left wall and R is 5 1/2' from right wall.
I'm waiting until I finalize the monitor placement to install the rfz absorbers.
Ethan Winer
Re: monitor placement advice
« Reply #1 on: March 28, 2008, 03:05:39 PM »
The only way to know where is best is to measure the LF response at high resolution as you try different places. If you use ETF or similar software, you can sweep continuously as you move the speakers around. Bribe a few friends with some beers to come by and help you and it will go even faster. Or slower. Very Happy
--Ethan
gullfo
« Reply #2 on: March 29, 2008, 08:43:08 AM »
you could probably go 6' on each leg of the triangle but pay attention to the strength of the phantom channel to ensure its consistent with the sides. move them in (as well as closer) if the center is "thin".
Glenn Stanton
www.runnel.com/
Barkley McKay
« Reply #3 on: March 29, 2008, 12:33:54 PM »
What is the optimum distance behind the speaker? I have Genelec 1030's which are ported from the front. I have gone for a LEDE type studio as the room is 14ft by 11 ft (but 13 into the aclove). I built 6 inch trapping behind the monitors into the alcove along with corner bass traps and two ceiling chunks above and into the alcove.
here is the plan:
index.php/fa/8333/0/
I think the room sounds pretty good, but have always wondered about the wall behind and speaker relationship.
many thanks for any input
Barkley
Barkley McKay
« Reply #4 on: March 29, 2008, 12:35:47 PM »
through the door photo:
index.php/fa/8334/0/
Barkley McKay
« Reply #5 on: March 29, 2008, 12:37:50 PM »
Alcove close-up:
index.php/fa/8335/0/
lostinthewires
« Reply #6 on: March 29, 2008, 01:19:53 PM »
Thanks for your replies.
How far from the ceiling do you think I should hang the two 2'x4' 4" rockwool absorbers?
Ethan Winer
« Reply #7 on: March 30, 2008, 11:51:00 AM »
Barkley McKay wrote on Sat, 29 March 2008 12:33
Same answer as before: The only way to know where is best is to measure the LF response at high resolution as you try different places.
--Ethan
gullfo
« Reply #8 on: March 30, 2008, 02:07:59 PM »
http://www.genelecusa.com/documents/qsg/QS2-way.pdf
this might help. Genelec has a number of excellent manuals on how to optimally set up their equipment. and do the measurements...
Glenn Stanton
www.runnel.com/
Barkley McKay
« Reply #9 on: March 30, 2008, 02:27:37 PM »
Thanks for the link. I actually have that document as it came with the monitors. I believe its aimed for non-treated rooms though with respect for using the 'tilts' etc. In my case I have some trapping behind.
I guess I was looking for info regarding the response behind the speaker as the frequency wavelength starts to exceed that of the dimensions of the speaker, and of the more omni-directional response as frequency lowers. Is it wise to keep it within a certain distance (back wall to front cabinet) etc.
As Ethan suggested, I think I am in the tweaking realm now with experimenting. I'll get some beers in!
Barkley
gullfo
« Reply #10 on: April 03, 2008, 05:38:52 AM »
i'd opt for keeping the monitors closer to the wall to ensure that whatever frequency range is wrapping has a long enough 1/2 wavelength, that the possibility of cancellation (from the front wall) at your mix position is lower. given you have angled boundary walls (alcove) you might find some low frequency anomalies so i'd beef up whatever trapping you have between the two speakers.
Glenn Stanton
www.runnel.com/
Barkley McKay
« Reply #11 on: April 03, 2008, 07:12:39 AM »
Thanks for the suggestions.
I have at present nearly 8 inches (after re-measuring!) of absorbtion behind, and there is definitely a better response with the speakers, bass wise, now that I have them backed up close but there seems to be a little lift in the upper bass/low mid range now.
Do you think it would be prudent to make a hanging 'cloud' bass trap above the alcove, and is it possible that I am getting ceiling to floor anomolies now?
The speakers are definitely beyond the half way point on the vertical axis. At present I do have two ceiling corner traps there (see 1st photo) but I do cherish the little window for natural daylight!
Barkley
gullfo
« Reply #12 on: April 04, 2008, 01:51:17 PM »
you should have a cloud overhead regardless but it doesn't have to block the window either...
Glenn Stanton
www.runnel.com/
Barkley McKay
« Reply #13 on: April 04, 2008, 01:59:52 PM »
I thought as much, time to get the saw out!
At the moment there are just auralex foam panels on the ceiling above the console for the early reflections.
The neighborhood cats sometimes visit through the window.
Again, thank you for your advice, much appreciated.
Barkley
Ian Visible
« Reply #14 on: April 07, 2008, 07:56:20 AM »
Cats make excellent absorbers but you will need to apply a fire retardent of some description as they also make excellent firelighters.
Sheep are even better.
Page created in 0.083 seconds with 20 queries.
