mgod wrote on Sun, 04 May 2008 12:42 |
Its all in the listening Barry - if you can't or don't hear it its not worth a cent. For me on this project it was worth anything, and our rental fee wasn't cheap, but a bargain nonetheless.
All the debate, all the alleged "fact", all the so-called scientific positioning re: PLL doesn't mean anything at all if the results sound more like actual music. Internal clock, lead vocal is flat like a cartoon on a plasma screen. Antelope rubidium clock in, vocal pops out in front of the speakers and has depth to it. Sounds closer to a real voice in front of you. (C-12/EAR 824M/660/PT9[192kHz]).... DS
OK. First of all, you might want to record and reproduce
at something lower than 192k Fs, but that's maybe because of PT converters? Yes, for a filter of a given quality, it normally sounds better to put it at a higher frequency wrt Nyquist, but - clock speed piss match rights aside - the chips presently in your DAC really need to relax between pulses for longer than 192k Fs allows in order for the most linear response, especially the low end (that is, for the good garbage in to equal the same garbage out)... That notwithstanding, if the vocals sound more present with the Rubidium clock engaged, it is most likely because there is more jitter in the monitoring chain. Since vocal presence is in the 1k-6k zone, and if you add jitter to a monitoring chain, those frequencies will sound more "forward" (for one), I fear that, like all external clocking scenarios, the Rubidium is able to dial in an exciting bulge of stridence that really shouldn't be there (during monitoring) and won't be there, either way, after the clock has been removed from the chain - or else it has done nothing, anyway. Internal clock is King for all time - sorry. And 4x Fs is great for some DSP, but not for conversion to or from analog - until chips get faster and/or more robust.
Andrew
