Author Topic: Leslie Retrofit  (Read 6390 times)
debuys
Leslie Retrofit
« on: May 19, 2004, 12:27:09 AM »
I was thinking of building a Leslie style rotator to place in front of a speaker. In other words something that I can use with a variety of cabinets, adjustable, but still standing on the floor in front of the cabinet. My amp tech suggested actually building a rotator with "brush" connections to rotate the mics themselves. Anyone seen or tried any of these ideas?
Thanks,
Robert
Robert de Buys
Dreamcatchers
1818 28th Ave
Homewood, AL 25209
ted nightshade
Re: Leslie Retrofit
« Reply #1 on: May 19, 2004, 01:42:24 AM »
I LOVE it! This from a guy with 7 leslies. I used to wonder, how do they get the speakers to spin? What happens to the wires? I had great plans to build leslies, now I own 7 vintage ones.
I had a friend who built a line of DC motor leslies you could spin at variable speeds- couldn't find a quiet enough DC motor though. For that matter, the new Suzuki/Hammond Leslies are not as quiet motorwise as the old ones.
FInally found a fantastic, near silent DC motor with variable speed control! On a Musser vibraphone- the motor assembly alone costs $800... still, it's just the ticket...
Ted Nightshade aka Cowan
There's a sex industry too.
Or maybe you prefer home cookin'?
Bill Park
Re: Leslie Retrofit
« Reply #2 on: May 19, 2004, 07:19:22 AM »
Or you could do as one of the local showcase clubs did here, and hang large industrial ceiling fans in front of your speakers.  Now EVERY song is "Crimson and Clover".
  Bill
Padboy
Re: Leslie Retrofit
« Reply #3 on: May 20, 2004, 09:24:37 PM »
ted nightshade wrote on Wed, 19 May 2004 01:42
Yup, the old/still made Ham-Suz servo pulsed 2 pole AC motors used in the 122A/XB and 147/A/XB series are an electronic bandage to a mechanical problem. The newer 21 series (designed in Japan) are a great remedy that does it right, but it's just as costly as your solution.
For people with 2 digit leslies with AC 4-pole motors only, there are several options. None of them perfect, but some of them are more perfect than others.
best,
pad
(11 leslies, 3 consoles, 1 spinet)
Do You Know Your HERTZ?????
Erik
Re: Leslie Retrofit
« Reply #4 on: May 20, 2004, 11:42:49 PM »
debuys wrote on Wed, 19 May 2004 00:27
The Beatles experimented with this in the "Tomorrow Never Knows" timeframe.
Here's a nice site devoted to some of this stuff:
http://mywebpages.comcast.net/vrbass/vibratone/
Note that the speaker drivers in leslie speakers are not part of the rotating assembly.
--Erik
Erik Gavriluk, Bomb Factory Recording Studios
"The modern trouble is not the use of machinery, but the abuse of it." --Gustav Stickley, 1909
debuys
Re: Leslie Retrofit
« Reply #5 on: May 22, 2004, 02:55:48 AM »
Let me explain a bit further. I am thinking of building a rotateing baffle to place in front of a speaker cabinet. I dont need a large bulky leslie cabinet. That takes too much space for my taste. I am thinking of literally building a rotator that I can face against the speaker itself. I need some "why that wont work advice" so I can modify or abandon plans. I am hopeing to spend around $300 in parts. However, I'd hate to build an ugly, useless wind free pinwheel.
Most gigs I do these days involve small amps (local) or roadies and backline. I have no interest in anything heavy for live gigs.
Robert
Robert de Buys
Dreamcatchers
1818 28th Ave
Homewood, AL 25209
Scott Helmke (Scodiddly)
Re: Leslie Retrofit
« Reply #6 on: May 22, 2004, 12:12:31 PM »
I've been playing with this idea a little, after I inherited a couple old tube-based turntable/amp things.  Sound pretty good with a guitar plugged into the mic input, and then there's that spinning thing...
I haven't tried it yet, but I was thinking in terms of having a stationary board with some pie sections cut out and then a similar rotating board just in front of that.  As it rotated the cutouts would line up and "open" to sound.  Just having a single rotating board didn't do much.  I also tried to build something like the bottom drum on a Leslie, but it would have needed too much work sealing edges and such.  Plus a turntable spins too slow, even at 78.
http://www.scotthelmke.com/team-downbeat-1.jpg
Padboy
Re: Leslie Retrofit
« Reply #7 on: May 22, 2004, 05:59:18 PM »
If you just set up 2 boards in front of each other, (like a camera shutter) you're only going to get a tremolo/volume effect. The major part of the leslie sound (especially in the higher frequencies) is from doppler because of the rotating horn 'throwing' the sound in a circle.
Anyway - why don't you try ebay for pre existing units pulled out of spinets?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=6 4430&item=3724811896&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=2 3794&item=3725869985&rd=1
Those are essentially the 'guts' that exist in the vibratones that Erik mentioned.
Or... a drum unit ripped out of a standard leslie? (bigger than the ones above for 15" speaks but would need more work -and a motor assembly- to work)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=6 4430&item=3725123098&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=6 4430&item=3725063786&rd=1
I'm just trying to save you the trouble of reinventing the wheel.
Pun intended sort of.
later
pad
doppler enabled
debuys
Re: Leslie Retrofit
« Reply #8 on: May 23, 2004, 02:21:44 AM »
Thanks Padboy!
That's exactly what I needed. Although I did pass piano proficiency, I still lack basic search skills on Ebay and "Leslie" turned up an uninturpretable mish mash for me....
I thought I was going to have to build a baffle and rotator from scratch. Um, reinvent the wheel as you said.
I bid on
If it's not right I believe at the least I can use the parts. If I loose the auction I know where to look for parts at least. Thanks for saveing me alot of time padboy. I am in your debt.
That was so easy that now I'm unprepared for the next step; implementation. Do you know any good links for Leslie style rotator maintenence, use and schematics? The above Item is different then what I had in mind but seems like the right place to start so now I'm in need of more info.
Thanks again,
Robert
Robert de Buys
Dreamcatchers
1818 28th Ave
Homewood, AL 25209
Stephen Fortner
Re: Leslie Retrofit
« Reply #9 on: May 23, 2004, 02:30:31 AM »
Don Leslie actually tried a bunch of different configurations, and settled on the rotating drum and horn assembly that's become a part of history. A lot of manufacturers have tried alternative takes on damping a speaker with some kind of rotating baffle, including Yamaha and Roland, and none of them sound anything like a Leslie.
In short, what you're proposing may well sound interesting and cool on guitar or keyboards as a special effect. If your goal, though, is to simulate the lush, throaty sound of a Hammond through a Leslie, don't try to simulate. Go for the real thing, or something from Motion Sound, or even the electronic simulation onboard a Nord Electro 2, Hammond XK3, or Roland VK series organ.
Stephen Fortner
Contributing Editor, Keyboard Magazine
Any opinions expressed here are entirely my own. They are not intended to reflect the opinions of any  publication or other organization with which I may be associated.
John Klett
Re: Leslie Retrofit
« Reply #10 on: May 25, 2004, 02:24:32 PM »
I am not sure what to suggest - the rotating drum would be different than a spinning board or a pair of shutters that open and close.  Since you want to kick this in as an effect you have to deal with getting it out of the way when you turn it off.  A drum thing would be as big as a small Leslie type thing anyway.  We have a couple items in the shop that belong to one or another of the gang here.  One does have an actual speaker and counterweight on an arm that spins like some sort of carnival ride.  The arm thing is belt driven and the is a button on the end of the axle that is isolated from the rest of the contraption that has a spring bearing down on it to act as a commutator to get the speaker hot to the rotating speaker.
The original motor was shot so we took a reel motor from an MCI JH-110 and a variable DC supply to make it work - it perfectly quiet and ranged from a slow creep to dangerously fast...  so now there is a foot pedal - like a volume pedal - to make that work.
John Klett / Tech Mecca
http://www.technicalaudio.com
Padboy
Re: Leslie Retrofit
« Reply #11 on: May 25, 2004, 08:00:42 PM »
debuys wrote on Sun, 23 May 2004 02:21
Thanks again,
Robert
Most anything leslie and/or hammond can be found here. Links are at the bottom of the page:
http://www.captain-foldback.com/
For an esoteric description of how it all works, try here:
http://www.theatreorgans.com/hammond/faq/mystery/mystery.htm l
Sounds like an Allen Gyrophonic or something similar. A friend of mine in Canuckia has one. The organ companies that didn't talk to Don about customizing his speakers for their specific organs and went their own way did some pretty outrageous things to get away from patent infringement. Most of them sounded like hammered shit. I'm being polite.
Anyway, read and Ahn-Choy
later,
pb
ted nightshade
Re: Leslie Retrofit
« Reply #12 on: May 27, 2004, 04:54:16 PM »
The other day I saw a thing labeled Leslie 102- looked like a 122 with two bottom rotors, complete with two sets of vents, one above the other, and the rotors had speakers built in- the speakers actually spun! Damnedest thing... didn't get to see it in action.
That's fascinating about the spinning speaker gizmo you describe, John- and a great source for a quiet variable speed motor!
ssltech
Re: Leslie Retrofit
« Reply #13 on: May 28, 2004, 01:59:13 PM »
...I had one o'dem! -the midrange speaker is fed through a 'Mercotac' ( www.mercotac.com )to avoid the 'noisy/worn-out brushes' problem.
The 102 is a very different sounding beast to the 122. Very worth hearing! -i think that the classic 122 arrangement is the best leslie combo though. The ramp-up/ramp-down is wierd on the 102, since the different mass of the rotating assembly in the middle tends to not sound as glorious as the high-inertia-low-end/low-inertia-high-end of the traditional 122-style arrangement to me.
Keith
MDM (maxdimario) wrote on Fri, 16 November 2007 21:36
I have the feeling that I have more experience in my little finger than you do in your whole body about audio electronics..
ted nightshade
Re: Leslie Retrofit
« Reply #14 on: May 31, 2004, 07:49:41 PM »
So it really was a 102- I saw it in an old hack shop junk shop so I didn't know if it was stock, totally mislabeled, or what...
Page created in 0.037 seconds with 17 queries.
