dcollins wrote on Wed, 09 April 2008 00:29 |
crna59 wrote on Sat, 05 April 2008 14:36 |
I'll solve the whole issue... <$5k Hypex wins.. >$5k Pass Labs wins!!
The Hypex should run with any amp, regardless of price.....
DC
Hi DC,
Not sure whether u are being sarcastic here, anyhow a few
comments wrt class D amps and one discussed (CI) in particular:
I dug up some measurements on the CI amp here:
http://www.stereophile.com/solidpoweramps/805cia/index4.htmlWRT distortion, there's plenty happening as you can see from the
spectrum plots. A good linear amp will still have quite a bit
less distortion than this and a very good one will have at least
10x less.
I have a nice linear power amp running which has somewhere around
100x less at close to full power (around -120dB / 20kHz / 200W /
4R).
Unfortunately I think if you compared a good -120dB/20kHz/FP
amp to the class D, you may still prefer the class D. The
'more extended top end' may be distortion? Clearly most good
linear amps are more extended and go to 100kHz or more.
Same goes for soundstage width and depth, guess why SET's have
unrivalled stage depth, width and dimension - a whole lot of
added harmonics in the right dose and area?
Maybe class D just distorts in a completely different way than
linear amps, (including xover distortion which is very audible),
so the end result -sounds- cleaner and more extended, which after
all is the most important thing.
It would be nice if these FFT plots would give some damn
indication of what these things actually sound like - very
frustrating field audio.
OK - Just some food for thought.
cheers
Terry
