ivan40 wrote on Fri, 14 May 2004 16:02 |
Oh;; I see what he's saying now ,I think. If I'm getting overs while mixing in Wave Lab for instance, the meter is indicating an over in the converter,not the software? So if I look at the wave form and see that it is clipped, It will be because the converter clipped. It would also show squared of audio that was clipped at the pre amp but, This clipping is not a result of the soft ware going over digital zero. Do I understand this now? Thanks.
Yes you're exactly right.
And when looking at the waveform, you can usually tell what is causing the clipping. A "squared off" waveform was clipped in the converter (highly unlikely). The sudden presence of 2nd or 3rd harmonic in the signal indicates clipping in some analog stage (probably the mic pre, or in the front end of the "converter", analog buffer/amplifier input). You can see this if you have, say, a vocal note that is predominantly a sine wave that suddenly develops a "dip" in the crest of the wave so it goes rise, then fall a little, rise back up, then back to zero. Make sense? The wave would look like this (maybe):
/\/\ / \ / \ <---analog clipping+ \ / \ / \/\/ ___ / \ / \+ \ / <---converter clipping (very unlikely) \ / \__/
What I was originally trying to point out is that it is nearly impossible for the RECORDED track to have digital clipping. You would have to overload the front end of the actual converter chip directly without distorting first in the analog driver that's on the input of the converter system. Your converters have a jack, probably a capacitor, then some kind of amplifier (dual op amp probably), then go into the converter. Any clipping you hear from a freshly recorded track is in this analog stage ahead of the converter. You'd have to ignore all kinds of audible distortion and really drive the hell out of it to get digital clipping on input, but you'd see it as a combination of harmonic distortion from the analog stage and flat-lining from the converter and it'd be nearly impossible to lay blame on one or the other.
Once the track has made it to disk, you can certainly crank it up to the level of overload of your converters, but this doesn't happen inside your DAW software, which in all liklihood uses 24-bit floating framework or 32-bit throughout, so there's all kinds of headroom on top of a 24-bit sample. You could add tons of gain to a normalized sample and still not get the internals of the DAW to clip. However, on output to the output converters, you can get it to clip because they have to output it at 24-bit (not 32-bit or floating). You will not see this clipping in the waveform unless you export the track and then you will see it in your exported track. You will hear it though!!!
My point was that the SM PR8 does not have enough headroom + gain to be able to overload the input of anything but maybe a SB16 card or a built-in laptop sound input... but certainly not a decent sound card or converter. So if you're hearing clipping in a track you just recorded, it's a recording of clipping that happened in the mic pre... the signal is clipped out of the mic pre. An easy way to tell is to plug the output of the mic pre on the suspect channel directly into your headphone amp and begin to play, see if you can hear the clipping. My guess is you can.
What I found with my Behringer console is that with a loud mic (like a LDC, in my case a Studio Projects B1), without a pad switch on the mic, regardless of the mic gain setting, the INPUT to the mic pre was clipping. Since the mic pre just has one gain stage, it clips in that stage, which are bipolar transistors so they sound awful when clipping. With other mics, if you crank the gain up too high, then it would clip in the mic pre, even though the thing was not outputting +4dBu. So my technique was to use the +14dB of clean gain in the front end of my DAW to give me an extra 14dB of headroom in my Behringer console so I didn't have to crank its gain enough to induce any clipping at all. Unfortunately this amplifies the noise. But c'est la vie. I guess in this case, it's a $200 console so it's hard to complain, same goes for a $100 8-channel mic pre.
