Author Topic: cell phones in the studio.  (Read 11101 times)
j.hall
« on: May 12, 2004, 05:04:12 PM »
this keeps hapening to me i need some ideas of what to do
i'm rolling tape, some one's cell goes off and now i have this static all over the track
i'm recording to 2" 24 track....and all the new cell stuff get's picked up on the head stack......what the hell?
it's nasty too
it get's into the console, monitors
makes me wonder if it'll screw up the tape when i'm simply in playback
or if some one sets their phone on a reel box and it rings.....YIKES
spankenstein
Re: cell phones in the studio.
« Reply #1 on: May 12, 2004, 08:51:00 PM »
I'm definitely not an expert on tape but cell phones work like a radio essentially. Nothing magnetic other than the speaker and I think that's too weak to do anything to tape.
I have noticed that GSM phones (t-mobile, at&t) make funny noises that often get picked up buy guitars before they ring and periodically when they "chat" with the tower.
j.hall
« Reply #2 on: May 13, 2004, 09:27:25 AM »
i'm on cingular, and my tracking engineer is on PCS
if we are rolling tape, "in record", and one of our phones' rings.  we get all sorts of strange static on the tape deck.
this is at his house (where all the mix room gear currently lives) and at two studios in town.
at first we thought the issue was isolated to his house since the deck is in very close proximity to where we are sitting.
but then it happened at a studio with a machine room about 20' away from the tape deck remote, and at another room with the deck about 8' away.
i can't risk this noise printing itself randomly to tape
does anyone know anything about this....do i just turn all cells off?
josh
« Reply #3 on: May 13, 2004, 10:31:17 AM »
Nothing magnetic?  Are you kidding?
The whole way a cell phone operates is with electromagnetic/electrostatic wave transmission.
When the phone transmits, there are two "fields" produced by the antenna and also by the amplifiers and other circuitry in the phone:  "H" field or "magnetic" field, and "E" field or "electric" field.
The "E" field is used for radio transmission.  Your gear is unlikely to pick this up, and even if it did, it's happening at nearly 1 gHz so you can't hear it.
The "H" field is useless for radio transmission because the intensity of this field is reduced at a rate of the inverse of the cube of the distance.  So this means the field is 1/8 as strong at 2 feet distance as it is at 1 foot distance, etc.  This is what you are picking up.
The H field radiation from the phone is incidental, it's not used for transmission and there is no "intentional" antenna in the phone to transmit on the H field.  The reason modern phones are more prevalent to this kind of noise (let me guess, it's a Sony-Ericsson phone, right?) is because the Li-ion batteries are a lower voltage, so the whole phone operates on a lower voltage and lower total circuit impedance.  Lower impedance means more current, more current means more H field.
The answer is to either turn the phone off, switch to a different phone that does not use the S-E chipset or design (although my guess is it will get worse with all phones as they progress), or simply put more space between the phone and the susceptible equipment.  My Sony-Ericsson phone will be picked up by anything magnetically sensitive within about a 6 foot distance...  10 feet and it won't pick it up.  Leave the phone in the other room at least 10 feet or more away from your susceptible stuff.
FWIW, this will probably print magnetic tape as well, at least to some degree.  It may build up magnetic flux on the tape heads requiring more frequent degaussing.  IMHO the real answer to your problem is to switch to digital Smile  just kidding.
If I accidentally leave my phone in my pocket during a gig or rehearsal where I'm playing my guitar, it cracks me up because invariably I'll get the delay set up to do near-infinite repeats or something, then the phone will make its noise and get picked up by the guitar pickup, and the delay plays it over and over and over...
See ya-
j.hall
« Reply #4 on: May 13, 2004, 11:01:58 AM »
WOW.....
that is the answer i'm looking for
help me out a little more if you don't mind
i only get that noise when my phone is actually ringing, it's not constant durring the ringing process
it doesn't happen while placing a call, or durring active concersation.....only while ringing
my phone is most commonly set to vibrate only, sometime ring and vibrate simultaneously....
would i elimante the problem if i just set the phone to silent while working.
i have a nokia
my tracking engineer has whatever sprint uses
is this a shielding issue?
i have static shields on all three decks it's happened on
josh
« Reply #5 on: May 13, 2004, 12:11:41 PM »
j.hall wrote on Thu, 13 May 2004 16:01
WOW.....
You'll get the noise when the phone is about to ring, ringing, or perhaps while it's idle "calling" the tower.  I have never heard a noise like this from my phone while it's operating (talking).  My guess is because the noise is actually caused because of a transitional state that the phone cycles in and out of during ringing and tower comm.
Look at it like this.  As you know, when discharged with no voltage across it, a capacitor is a short circuit.  When a change in voltage across the capacitor occurs, then current flows through the capacitor until it becomes charged, at which point current won't flow any longer.  This is by definition a transient current.  If it's AC, then current will flow the other way when the waveform polarity changes, etc.  But with DC, like the voltage running your cell phone, the cap charges up and then current only flows if it discharges.
The decoupling caps, filter caps and all that on the DC line will do this when you turn a DC circuit from "off" to "on".  So when your cell phone is sitting there doing nothing, the circuitry that's there to ring the phone is "off".  It's in standby, some other state of low-current, or maybe in reset or powered off.  Phones are designed to conserve power.  When it rings, this circuit is turned on, and there is a spike in current flow which is the very definition of what causes an H field to occur, change in state of current flow.  When it goes off, then the capacitors and other things discharge (another current spike, opposite polarity), then if it comes back on, another current spike, etc.  This is what's causing the noise, methinks.  Not for sure, but an educated guess.  If you hear the noise BEFORE the phone rings, this is the cause.  If you hear the noise occasionally when the phone is idle, this is the cause.
The vibrator in the phone is an electromechanical transducer like a speaker (actually it's like a solenoid).  It will DEFINITELY make a cyclic magnetic field.  If you only hear the nosie while it's actually ringing (vibrating), then turning off the vibrator in the phone might alleviate the problem.
Try setting it to ring only and see if it helps.  IMHO it might.  If it were a Sony-Ericsson phone, I'd think it wouldn't help.
No.  Shielding does not work on magnetic fields, unless you use a high permeability material like mu metal (very expensive, not likely you can use it).  You could shield the phone with mu metal and it might work, but it would be very hard to use the display, hear a conversation, or push a button Smile.  Maybe you need a mu-metal holster for it Smile
Your shielding is used for other things (notably, it's really used to improve grounding, but I don't want to get back into that debate).
j.hall
« Reply #6 on: May 13, 2004, 01:05:25 PM »
awesome man.....
i'll try running the phone in ring only and see what happens with a little blank tape....then put it in silent
pin 1 arguments..............boy that sounds like fun
spankenstein
« Reply #7 on: May 13, 2004, 01:39:53 PM »
I just don't see the difference between cell and say radio, or 802.11 wireless or cordless phones. Now the electrical interference could definitely end up on tape if the equipment (amps, guitars, console) pick it up but I am saying that I don't see the cell phone have a direct effect on the tape.
There was a thread on recpit about flying with tape and the X-ray machines. This should be the same.
josh
« Reply #8 on: May 13, 2004, 02:48:12 PM »
spankenstein wrote on Thu, 13 May 2004 18:39
Well, neither is it the same, nor should it be the same, but you would have to understand the difference between magnetic fields and electric fields and wave propagation through air and all sorts of other things to really get why.
The phenomenon that j.hall is describing with his cell phone is not related to radiated electric fields such as the signal transmission of a cell phone communication, or of an 802.11 (2.4gHz) Ethernet device or a cell phone (900-5400 MHz depending).  It's related to magnetic field coupling in the near field, which is stimulated by some other effect of the phone other than the direct RF activity of the transceiver.
Put more simply:  THIS IS NOT RADIO INTERFERENCE
It's a magnetic phenomenon that is not related to the radio transmission of the cell phone.
Radio interference does not passively effect magnetic tape because it is not a magnetic field, it is an electric field, and magnetic tape is not susceptible to electric fields by itself.
Now, regarding X-rays...  man you are off the reservation there.  X-rays are 10 BILLION GHz to about 100,000 BILLION GHz.  Most definitely not a magnetic phenomenon.  Even the smallest amount of measurable inductance would render a circuit unresponsive to X-ray-rate radiation.
FWIW, j. hall, in case I didn't make it clear, I doubt this magnetic noise is directly coupling to the actual TAPE or to the tape heads.  Tape heads are pretty well shielded normally (effectively, and by design, by people who understand electromagnetics), and should not be highly susceptible to this noise.  You'd have to have the phone very near to the tape head (sitting on the machine for example) for the HEADS to pick up the noise.  The same is true for magnetic tape.  You can evey operate a degausser within a few meters of a magnetic tape without damaging it, and it has a much higher magnetic field than your cell phone.
No, the reason you hear this "on tape" is because the noise is being picked up by some other susceptible device (a microphone, preamp, mixer channel, guitar amp, guitar pickup, cable, DI box, you name it, they can all pick it up) and you're recording the output of that device onto tape.  I bet if you disconnect all of the inputs of the tape machine and put on a tape, roll it and record it, then induce this noise by calling your cell phone with it in your pocket or a reasonable distance (1 meter or more) from the tape heads, you won't hear a thing on the tape.  Worth a test.  You can always erase it!
If magnetic media were this wildly susceptible to stray magnetic fields then computer hard disks would be completely non functional in the presence of a CRT monitor!
j.hall
« Reply #9 on: May 13, 2004, 03:28:39 PM »
josh, once again, you have answered questions i haven't even asked yet.
thank you SO MUCH, for the help.......i've been really nervous about this.....and now i've got answers.
josh
« Reply #10 on: May 13, 2004, 03:54:53 PM »
j.hall wrote on Thu, 13 May 2004 20:28
Glad I could be of assistance.
Hope this helps.
See ya-
j.hall
« Reply #11 on: May 13, 2004, 04:13:40 PM »
oh it helps.....big time
i know what is happening now, and "knowing is half the battle"
hahahahaha
Rivers
« Reply #12 on: May 13, 2004, 10:47:28 PM »
This finally became an issue with a session the other day.
The guitarist and I were doing some overdubs and trying to work out a solo and his damn cell kept ringing like every 10 mins.
It just totally destroys the flow/vibe of the session.
I think from now on I am going to either have the bands cut them off or leave them outside the room.
Smell the Magic
http://www.katp.com
stickman
« Reply #13 on: May 14, 2004, 12:04:55 AM »
ok, i cant speak for tape (i just wish i could...)
however, i think something similar happened to me one day. if someone could explain it to me, that'd be great!
so the story goes something like this...
was tracking a vocal to harddisk when my phone rang. i keep recording the singer in the studio while i talk on the phone in the control room. now, i didnt notice it on immediate playback but later on i realise my entire conversation is somehow recorded on the track. low in volume, but its definitely there and clear as day when listened for. every word. clear as day.
is this similar to what you guys are talking about because i didnt know this could happen?
how would this happen? did my voice somehow transmit or intefere with the signal as it went through the console, therefore going onto disk?
or is this common? (i dont get many calls...)
josh
« Reply #14 on: May 14, 2004, 11:42:27 AM »
stickman wrote on Fri, 14 May 2004 05:04
This is not the phenomenon that j. hall was talking about.
Sounds to me like you left the talkback mic on Smile
digital cell phones use encryption and encoding mechanisms that would be impossible to pick up as interference that would be intelligible.  If it was an analog cell phone then it's possible you have a fine-tuned 900 MHz receiver in there somewhere (like the guitarist's cheap wireless rig?).
