lostinthewires wrote on Mon, 21 January 2008 20:11 |
I especially don't know what to do with the little corners either side of the fireplace
Small things like that are not nearly as important as the outer corners of the room. Stuff behind the mix position matters even less.
You didn't ask any real questions, and I'm too busy to type a 14-page dissertation on how to treat a room.
Luckily for you, I already did that a while ago.
So here's my canned reply:
Room treatment is a deep subject, and a complete answer requires far more than will fit into a single reply here. So here's the short version. All rooms need:
* Broadband (not tuned) bass traps straddling as many corners as you can manage, including the wall-ceiling corners. More bass traps on the rear wall behind helps even further. You simply cannot have too much bass trapping. Real bass trapping, that is - thin foam and thin fiberglass don't work to a low enough frequency.
* Mid/high frequency absorption at the first reflection points on the side walls and ceiling.
* Some additional amount of mid/high absorption and/or diffusion on any large areas of bare parallel surfaces, such as opposing walls or the ceiling if the floor is reflective. Diffusion on the rear wall behind you is also useful in larger rooms.
For the complete story see my
Acoustics FAQ.There's a lot of additional non-sales technical information on my company's site - articles, videos, test tones and other downloads - linked under my name below.
--Ethan
