sadworld wrote on Sat, 08 May 2004 01:16 |
some things i've read recently prompt me to ask this question... what is the input impedance switch on pres for? for example , my x73i is switchable between 1.2 and 300. the manufacturer basically said i will never have to use the 300 setting. what is that for and what will it do for me if anything... thanks, matt.
Hey Matt,
There are two types of electric circuit designs we must discuss to understand this question. The first is the impedance MATCHED circuit, and the second is the impedance Bridged circuit.
In a circuit where the impedances (input and output) are matched, it can be shown that maximum POWER transfer takes place. This is a classic problem in any introductory circuits textbooks, and some introductory physics texts. There are additional advantages of this topology when you talk about transmission lines, but audio frequencies are far too low to worry about them.
On the other hand, most (all?) audio interconnect circuits work in the bridged topology, where the input impedance is substantially higher than the output impedance (usually aroud 10:1). This results in the majority of the voltage being transferred from output to input, and keeps the amount of current that must be sourced by the output devices small.
On your device, 1.2 probably refers to an input impedance of 1.2kilo ohms, and 300 to an input impedance of 300 ohms. if the output impedance of the FET inside your condensor mics is nominally 150ohms, 1.2kohms is a bridging impedance.
Somewhere out there in the world of audio past there are probably microphones (likely tube microphones) that have output impedances of around 300ohms, and need a matching impedance. One of the microphone guys will have to pipe up here, as I am simply too young to know.
Switching over to the 300 ohms switch with your average run of the mill microphone will cause it to have to source more current. For a condensor this could me the FET leaves its linear range sooner, which will produce harmonics that you may or may not find pleasing. Your condensor mics electronics may not take kindly to this lower input impedance.
On a dynamic microphone you will be changing the effective electrical q component of diaphragms damping. This also may, or may not prove auditorially interesting.
There are other subtleties of the effects of input impedance, but this probably answers your question.
As an aside, impedance matching is one of the most important concepts in science. The optical analog (index of refraction) the mismatch determines the amount of reflected and transmitted light. The acoustic analog (radiation impedance) determines how well a source reflects sound, or loudspeaker couples to the air. Finally, in the electrical world, matched impedances are important at higher frquencies (Mhz+) to reduce the amount of reflection back down the cable, which now acts as a transmission line.
Whew!
