Quote: |
very interesting. especially your project for graduation. are you focusing on music or post production?
I'm mainly focused on music production.
Quote: |
i'm asking this, because i try to compare radio play production with post production and with music production (in 5.1, of course). what do you think about the usage of the LFE and the C-channel in music productions?
For music I tend not to use the LFE, only for SFX maybe. I let the bassmanagment do his work for feeding the subwoofer.
The center-channel always is a hot point of discussion. I feel when I put something (e.g.vocals) alone on the center-channel it doesn't really glue with the rest of the soundfield. There's just not enough coherence. But, the center can help to anchor something to the center. I do use the center in combination with the LF and RF. Then I put the center image usually about 3-10 dB lower than the LF an RF. I also the center to pan something between LF and RF. E.g. when you want to pan something halfway left, you can just use LF and RF, but you can also use C and LF; if you put an equal level on LF and C you get a phantom image halfway C and LF. Then, I can also use the RF for some divergence maybe.
Quote: |
do you know the "rule of the first wavefront"? localization is not influenced by reflections that come to the listeners ear right after the direct sound - the "rule of the first wavefront" says, that these reflections even can be up to 10 dB louder than the direct sound as long as they are delayed for 5 to 50ms. localization will be uninfluenced.
That is the Haas-effect. What I use is 'phantomlocalization' which is working with delay shorter than 5 ms. When panning something to hard to one side 1.5 ms delay on the other speaker would be enough.
Quote: |
this might be very useful for the application of 5.1 placement.
I don't know yet. How do you think that could be useful? Do you know the theories from Madsen?
