I have this nice wheely thing that I bought from IKEA for about
« Reply #9 on: November 20, 2007, 12:18:56 PM »
Patrik T wrote on Tue, 20 November 2007 13:54 |
aivoryuk wrote on Tue, 20 November 2007 13:55 | I have this nice wheely thing that I bought from IKEA for about
« Reply #10 on: November 25, 2007, 03:40:30 AM »
i never had any problems with the equilateral triangle rule; the listener should be as far back from the speakers as they are apart from each other. currently, i'm near field, with my HR824's three feet apart and myself three feet away. it's like being in a cocoon... mmm... cocoon.
- j a s o n | s t e r l e - myspace.com/quantumpsych
« Reply #11 on: November 25, 2007, 10:09:07 AM »
The Dunlavy manual says that the best distance for their far-fields is 9-12' in front of the listening position. Their manual also suggests putting the speakers in opposite sides of one of the long walls, with appropriate toe-in for the image to point at the listener, who should sit along the opposite long wall. Also, the listener should sit with his ears at tweeter height when listening to an M-T-M array. I have departed somewhat from the recommended starting position described above, since my long walls are not appropriate for having as front and back, because the short walls are not symmetrical in their rather permanent acoustic treatment. One is a large, vintage shag carpet-covered bass trap/dead end, the other is a flagstone rock wall/live end with parquet floor. It used to be a late 70's tracking room. I have therefore placed the speakers about 9 feet apart from each other along the large bass trap wall and sit about 12.5' in front of them, in front of the rock wall with a somewhat narrower (4' H x 8' W x 4' D - filled with Roxul
www.serifsound.compremastering for CD and DVD-A. Featuring FTP load in and delivery as well as analog tape transfers.
« Reply #12 on: November 25, 2007, 11:12:15 AM »
« Reply #13 on: November 25, 2007, 11:54:15 AM »
He won't listen.
Too busy making money, I guess.
I think it depends on the drivers too. Dome radiators have a wider sweet spot, compared to say, cones.. You can move around more.
« Reply #14 on: November 25, 2007, 08:09:56 PM »
Hi "Peter," I did read it and also looked at the BMW links. There was also something in there about a Petula somebody. Oh, the RH that I referenced wasn't Ross, but engineer Ryan Hewitt. He has a 335i, the B*stard. Nice car. DC
« Reply #15 on: November 27, 2007, 04:21:59 PM »
that guys method leaves you sitting almost directly at the center of the room. Not a good idea! and his web site goes on to say "An infinitely indivisible progression known as the Fibonacci sequence or golden section is the key to resonance control. The ratio of Phi, or 1 to 1.6180339887...to infinity, is the Golden Mean, called golden ratio or golden proportion. Cardas Audio holds the patent, U.S. Patent Number 4,628,151, where the ratio of Phi is applied to any electrical conductor. In Golden Section Stranding, strands are arranged so that every strand is coupled to another, whose note is irrational with its own dissipating conductor resonance. This creates a silenced conductor, allowing Cardas cable to produce the purest possible audio signal. No other cable geometry, no other conductor design, can create the listening magic of Golden Section Stranding." Those patented Phi/Fibuonacci sequence cables are golden alright! Golden Goose Eggs!
« Reply #16 on: November 27, 2007, 05:23:05 PM »
PP wrote on Sun, 25 November 2007 11:12 | “Mispelling is often the sign of a good tech”
Dear Tom, You must be a brilliant technician. The word ‘mispelling’ does not even occur in the dictionary. I believe the word you meant to write is ‘misspelling'.
But misspelt it.
Sorry just catching up on this thread. No that spelling was intentional P. it's called a joke ... Glad to see that you picked up on the subtlety. PP wrote on Sun, 25 November 2007 11:12 |
My purpose in writing is not to correct you, but to publicly convey your convincing technical prowess and engineering experience to the whole world.
I'm concerned...
Has there been too much fungicide sprayed on the apples you’ve been eating recently?
As appears to be the case demonstrated here...
http://www.gearslutz.com/board/mastering-forum/156681-who-ha ndsome-young-man.html
Also a joke? To quote one of the great bards of the late 70's: "Does anyone remember laughter?"
« Reply #17 on: November 27, 2007, 05:45:10 PM »
Quote: | "An infinitely indivisible progression known as the Fibonacci sequence or golden section is the key to resonance control. The ratio of Phi, or 1 to 1.6180339887...to infinity, is the Golden Mean, called golden ratio or golden proportion. Cardas Audio holds the patent, U.S. Patent Number 4,628,151, where the ratio of Phi is applied to any electrical conductor.
Vincent Van Haff! And the "Golden Mean"! It's back!
« Reply #18 on: November 28, 2007, 08:21:52 AM »
brett wrote on Tue, 27 November 2007 16:21 |
I personally don't agree with everything Mr. Cardas says BUT his system for setting up speakers seems to work for my situation(with a little "by ear" tweaking). I think his cables are overpriced and some of his ideas about cables are a bit "off the wall" from a physic's standpoint but he seems to sells a lot of them to golden eared audiophiles..... I noticed that you were quick to shoot down this method but did not offer any suggestions that you had used and worked well for you so could you enlighten me what system you use in your "mastering room" and why you have found it to work so well. By the way if you do the math you will see that you are NOT in the middle of the room if you follow the advice quoted in my original post.
-TOM- Thomas W. Bethel Managing Director Acoustik Musik, Ltd. Room With a View Productions http://www.acoustikmusik.com/Doing what you love is freedom. Loving what you do is happiness.
« Reply #19 on: November 28, 2007, 10:33:09 AM »
Larrchild wrote on Tue, 27 November 2007 22:45 |
Goooooooold!
"T(Z)= (n1+n2*Z^-1+n2*Z^-2)/(1+d1*z^-1+d2*z^-2)" - Mr. Dan Lavry "Shaw baa laa raaw, sidle' yaa doot in dee splaa" . Mr Shooby Taylor
