R/E/P > Budget? Budget? We Don't Got No Steekin' Budjet
ADK S-7b, A real Gem!
Trumpetman2:
Not that I could tell.
compasspnt:
Both of my Neumann M-49's came with only solid mounts.
Never problem.
Six of my eleven 87's came with solid mounts.
Never a problem.
All six of my 414-EB's came with only solid mounts.
Never a problem.
Not that there might not ever be a situation where an elasticised spider mount mightn't improve something, but the "need" for these is way, way overblown.
Just like a lot of things in the gear world today.
Sounds like Larry is doing good things with his "B."
(Larry, I will still be checking in with you to get some mics, just been too busy.)
Larry Villella:
Thanks for all the lively comments gents!! End-users Rule!!
There is a heavy-duty shock mount due end of December for all the new generation ADK, including the S-7.
The irony here is that JP predicted the "B" Vesion would be perfect for Brass !! ADK is nothing without our design-engineers.
On that point, as of the end of this year, 100% of all ADK Audiophile Series Mics will be built in this new factory (where A6 / S-7) are made, with 100% new electronics, capsules, and exceptionally rigorous QC.
The proof is in the consistancy, durability, and musicality!!!
For Rock And Roll - Give me an S-7. But for Horns, I love the new S-7 "B" version.
ADK's long-term goal is to build a mic to cover every source-material.
Glad to hear we're making some headway . . . .
Galil:
Larry Villella posted in another thread:
It is possible to TUNE the S-7 to be several shades "darker"
We created two Darker Shades of the S-7 for evaluation.
Chestnut Ale and Guiness if you like . . .
It seems that Trumpetman2's favorite of the S-7s is the darkest of the microphones (Is this right?). Larry, is that the popular one in other quarters, too?
I think that marketing it as a "brass" microphone might be a mistake. It seems that there are many "bright" large diaphragm condensers but there may be quite a bit of room for darker-voiced LD microphones. I have a much easier time mixing when every track does not have a presence peak between 5khz and 15khz.
Galil
Larry Villella:
I think it could be explained this way -
Trumpetman picked the exact variation (B) that JP predicted would be the most useful color for Brass.
The "C" version turned out to be a bit off the mark.
For Most Rock and Roll High SPL Sources, we think the stock version S-7 (marked A for the blind-tests) is spot-on.
For Brass, Reeds, the S-7B is getting exceedingly positive responses. I think of it as a Hamburg Version of S-7.
If someone wanted a Vienna Version, we're capable of offering that up, too. Our High SPL mic has adaptability. (Why not?)
Indeed, the ADK Custom Shop is set up to build one-offs of Any ADK product.
As a practical matter, are there enough brass and reed players out there to support a separate production model?
Only time will tell . . .
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
