Author Topic: 32 bit 64.000 kHz file for mastering  (Read 3986 times)
Andy Krehm
« on: November 12, 2007, 02:04:31 pm »
I got a 32 bit 64.000 kHz file for master.
Oviously I understand the 32 bit part but have never seen 64.000 kHz file.
Anyone?
Dave Davis
Re: 32 bit 64.000 kHz file for mastering
« Reply #1 on: November 12, 2007, 02:33:44 pm »
Are you talking sample rate (as in 64,000 kHz)?  That's definitely a wierd number!
In theoretical terms, 64K s/r has been discussed as an "ideal" compromise between bandwidth needed for our ears and anti-imaging filters and efficient transport, but I'm unaware of any commercial systems using it in the field.
Are you sure it's not a 32kHz s/r, saved with 64 bit native (d/p) words?
Interesting...
-d-
Andy Krehm
« Reply #2 on: November 12, 2007, 02:50:37 pm »
Dave Davis wrote on Mon, 12 November 2007 14:33
Interesting...
-d-
I'm using Wave Editor to analyze and convert and it definitely says Rate: 64.000!! It's the only program I have that will recognize it.
I tried converting it to a 24 bit file and load it into Pro Tools but PTs wants to convert it to one of the standard rates.
I've sent an email to the client to see if he can tell me what's going on.
TotalSonic
« Reply #3 on: November 12, 2007, 03:44:33 pm »
There's no DAC I know of that can output 64kHz (although later generation DAT players often had 32kHz as an option for "extended play" modes).
One thing I like about SAWStudio is that it can load a wav or aiff file at any standard or custom sample rate up to 384kHz and then play it back using a realtime SRC algorithm at any other rate you wish so that you can preview it without having to perform src to the file first.
Best regards,
Steve Berson
cerberus
« Reply #4 on: November 12, 2007, 07:24:21 pm »
Andy Krehm wrote on Mon, 12 November 2007 14:50
unless the mix engineer is a kinky monkey,  it's likely that the data was
written in some earthly format. perhaps the header is screwey.
jeff dinces
Andy Krehm
« Reply #5 on: November 12, 2007, 11:22:56 pm »
Here's an excerpt of what my client had to say:
"....It was all done on Cubase. and i figured out that it WAS happening during the save stage for the .wav files. So all of the finished files that remain in the program are all standard, but all of the wav files that were being saved outside were being saved as 64 kHz. hahah and don't ask me why this is but throughout the project cubase has thrown random mysteries our way.. so i guess i would rule it as some sort of weird cubase thing. Now that it's been recognized hopefully it'll stay fixed.. i've never checked the actual sample rate of any of the bounced wav files yet so i don't really know how long this has been going on...."
(the above is from my client so if quoting please do not attribute it directly to me!)
BTW, I just heard from someone that Radar 7 actully will allow one to mix at 64 kHz.
masterlab
« Reply #6 on: November 13, 2007, 04:13:08 am »
So Cubase did a SRC to 64kHz (it can do all SRC/sample rates during export).
If possible, ask for bounces in native samplerate.
If impossible, prepare for a slight edgyness...
-a-
___________________________
    andreas balaskas
chief mastering engineer
    www.masterlab.de
Andy Krehm
« Reply #7 on: November 13, 2007, 09:00:43 am »
masterlab wrote on Tue, 13 November 2007 04:13
He is going to rebounce but is obviously a newbie at this.
What is the Cubase native sample rate or where should he look to find it?
It's been my observation that a lot of people just boot up a session and just start recording with no awareness that they can select a bit/sample rate.
MoreSpaceEcho
« Reply #8 on: November 13, 2007, 09:58:20 am »
i think Wavelab can read/write 64k files...
i got a project in for mastering once where all the files were 24 bit/44.2kHz. if anyone can make sense of that one, i'll buy you a cookie.
hnewman
« Reply #9 on: November 13, 2007, 10:37:33 am »
MoreSpaceEcho wrote on Tue, 13 November 2007 09:58
That probably was a file either output from or destined for flash animation.  It needs to run at 22.079 khz or a multiplier thereof in order to keep time properly.  Don't ask me why.  This guy explains it, but I'm not so good at the reading.
http://www.funnygarbage.com/flog/index.php?/archives/35-Dave s-Flash-Tips-of-the-Week-1-22.079kHz-The-Magic-Number!.html
Mmmm, cookies.
masterlab
« Reply #10 on: November 13, 2007, 11:55:10 am »
Andy Krehm wrote on Tue, 13 November 2007 15:00
It's a setting he needs to do while exporting:
index.php/fa/6645/0/
If it is NOT the projects native samplerate Cubase will SRC.
The project sample rate can be set elsewhere and gives an error if it is not the same as the SR of the audio hardware.
-a-
    andreas balaskas
    www.masterlab.de
Bob Boyd
« Reply #11 on: November 13, 2007, 12:24:00 pm »
hnewman wrote on Tue, 13 November 2007 09:37
Mmmm, cookies.
Interesting.  While it doesn't quite round up, my first guess would have been that 44.2k was somehow tied to the video "pull-up" rate of 44144Hz.
Bob Boyd
ambientdigital, Houston
http://ambientdigital.com
Twitter: @bobboyd
MoreSpaceEcho
« Reply #12 on: November 13, 2007, 12:53:22 pm »
afaik the files were from one of those roland VS1680 dealies and didn't have anything to do with video or flash or anything. but who knows. have some cookies anyway.
http://www.library.drexel.edu/blogs/thesuggestionbox/Cookies.jpg
Bob Boyd
« Reply #13 on: November 13, 2007, 02:35:35 pm »
but it begs the question - did it sound .1 better than 44.1k?
Bob Boyd
Twitter: @bobboyd
hnewman
« Reply #14 on: November 13, 2007, 02:50:08 pm »
Bob Boyd wrote on Tue, 13 November 2007 14:35
I just tossed my cookies.
