Author Topic: What's your chain?  (Read 9651 times)
bblackwood
What's your chain?
« on: May 02, 2004, 05:07:50 pm »
I'm sure some guys have a ton more gear than I, some less, but assuming you were to list most everything you commonly use in your chain, what would it look like? What pieces of gear/software do you love?
Brad Blackwood
euphonic masters
Invisible Member
Re: What's your chain?
« Reply #1 on: May 04, 2004, 10:54:57 am »
Come on Guys... Homeland security won't confiscate anything you list Smile  If mastering chains are not a secret then why the silence?
Peace,
Dennis
MASSIVE Mastering
« Reply #2 on: May 04, 2004, 12:40:10 pm »
First, I add cowbell to everyone's recording.  They'll like it.  I know they will.
Then, it's a trip through the Stereo Stupidifier with the Digital Sonic Decrapulator mod.
Then, perhaps some EQ, a quick run through a hot-rodded optical tube compressor, into the Apogee's, yada, yada, yada.  Monitored through the B&W 802's and a set of modified Wharfedales.
Shocked
John Scrip
Massive Mastering - Chicago (Schaumburg / Hoffman Est.), IL - USA
duaneadam
« Reply #3 on: May 04, 2004, 06:54:44 pm »
Massive,
That cowbell video clip had me rolling.
Duaneadam
bblackwood
« Reply #4 on: May 04, 2004, 07:25:38 pm »
Massive - can you give us more details as to what you're actually using?
Duaneadam - same for you?
Here's mine:
Analog (Studer A80) -> Crane Song EQ -> Sontec EQ -> Pendulum Compressor -> Crane Song Commpressor -> Crane Song ADC -> dbx Quantum -> L2 -> DAW -> Lavry DAC -> PassLabs amp -> B&W N802s w/ Velodyne DD12 sub
Digital source is same but has it's own Lavry DAC for playback.
Come on, share your toys!
Brad Blackwood
euphonic masters
MASSIVE Mastering
« Reply #5 on: May 04, 2004, 08:22:17 pm »
Geez, after that list, I'm gonna look pretty low-rent...
Here's some of it...
It's humble, but it's what I've got.  Back in "the day" I had access to much better gear, but now I do much better work.  Little by little, the gear will come I guess...  It was just way easier when someone else was paying for it!  Laughing
John Scrip
jlapointe
« Reply #6 on: May 04, 2004, 09:03:43 pm »
bblackwood wrote on Sun, 02 May 2004 18:07
Studer A807 (repro only) > Manley Massive Passive > Normandy Baxandall EQ > Normandy tube line amp > Pendulum ES8 > Crane Song HEDD AD / process > L2 > Benchmark DAC-1 > Yorkville amp > JMLab Electra 926 speakers
Digital sources come from the HEDD DA.  Occasionally a problem source will get a little Waves C4, or some parallel compression in Samplitude.  I also have a Samplitude template setup to do some "ambience extraction / enhancement" as in the Bob Katz K-Stereo box, but I rarely use it.
The Normandy stuff is of my own design.  The Baxandall eq is basically a hi-fi version of the standard home stereo bass and treble control.  For some projects it doesn't need to get any more complicated than that.
Most of the chain has been modded in some fashion, and I'm sure most of you do the same to your stuff.  I'd be interested in knowing if any other ES8 users have modded the output gain controls.  I ordered the parts to make mine linear with max 6db of gain, but I'm getting used to the fiddly stock controls so I might just leave em.  Brad, is the output of Pendulum opto comp fiddly at all?
- J. LaPointe
bblackwood
« Reply #7 on: May 04, 2004, 09:45:46 pm »
JLaPointe wrote on Tue, 04 May 2004 20:03
Yeah, but I only adjust the threshold, ratio, attack and release times - I leave the output at 0...
Brad Blackwood
euphonic masters
Phil Demetro
« Reply #8 on: May 04, 2004, 09:53:23 pm »
OK, here's my list... but don't ask me how any of it works, though!
Analog (Ampex 102) (if Digital (ProTools) -> Mytek DAC) -> Focusrite 330 Compressor-> Focusrite 315 EQ -> Maselec MDS-2 De-esser -> Manley VMu Compressor -> Sontec 432C EQ  -> Neve 32087 EQ -> Weiss EQ 1 -> Weiss DS-1 MKII Compressor -> Z-SYS Z-Q2 EQ -> T.C. Electronic Finalizer -> L2 -> Sadie -> Mytek DAC -> Brystons -> Custom Audio Hardware Loudspeakers
Mytek WC -> Rosendahl  -> any available WC
Shunyata Research AC and power distribution
Phil Demetro
Lacquer Channel, Toronto
____________________________________________________
Phil Demetro
Mastering at The Lacquer Channel, Toronto
http://www.lacquerchannel.com/phil-demetro/
Ed Littman
« Reply #9 on: May 05, 2004, 02:47:02 am »
MCI JH110->1/4 & 1/2" Cranesong stc-8-> Cranesong ibis-> Mytek adc-> SIR reverb, waves plugs etc->Wavelab-> Mytek dac-> Coleman audio m3ph stepped monitor select w/VU mod-> dorrough 40-c meters-> Bryston 14b-> dunlavy scIIIa's.
JA Michelle orbe turnatable-> ear tube phono amp-> mytek adc
I'm waiting on some siemans u373 comps to be fixed(really snappy). just sold a ton of german eq's ,comps, & the fatso.
has anybody shot out the mytek adc with the crane song hedd?
Ed
duaneadam
« Reply #10 on: May 05, 2004, 11:24:34 am »
DA Conversion
            Lavry Blue
            Lavry Gold DA924
            Weiss DAC1 MK2 24/192
Analog EQ
            Manely MP
            Manley Stereo Pultec
            Cranesong Ibis
            Avalon 747
Analog Comp/
Limiters
            Manley Vari MU
            Manley Slam
            Alan Smart C2
            Pendulum ES-8
            Crane Song STC-8H
AD Conversion
            Lavry Blue
            Lavry Gold
            Weiss ADC2 24/192
Digital
            Weiss EQ1-LP
            Weiss DS1-MK2
            Waves L2 Hardware
            Sony DRES777
            TC M4000
            Eventide DSP7000
Monitoring
            Proceed HPA (5 Ch)
            Parasound 1500 A
            Integra 7.1 Processor
            Revel Gems
            Martin Logan/Velodyne Subs
            B & W 1nt (for Surround)
            Tannoy Reveal
Duaneadam
davidc
« Reply #11 on: May 05, 2004, 12:35:34 pm »
Analog Tape
Studer A80 1/4 (Custom electronics)
Studer A80 1/2 (Custom electronics)
DA Conversion
Apogee AD8000 (modified)
XTC Dac (prototype)
Analog Outboard
Manley Vari-Mu Comp (modified)
GML 8200 EQ
AD Conversion
DAW
Protools Mix (44.1 & 48 only)
Wave plugins (inc L2)
Reverb
Lexicon 300
Monitoring
XTC active preamp (prototype)
XTC power amp (prototype)
Alon Phalanx/Poseidon speakers (modified)
Cable( Very Happy )
Wireworld
Audio Magic
Van Den Hul
I am pretty happy with the setup, with following caveats:
I would like an alternate compressor (ST8?)
I would like an alternate EQ (Ibis?)
I will need to move to 96k, but don't want to move to PT HD, although I want to stay with the Mac.
Best Regards
David C
D Harris
« Reply #12 on: May 05, 2004, 04:23:30 pm »
Ampex ATR-102 or Digital format>Millenia NSEQ2>Manley Vari-Mu or Tube Tech LCA 2B>Manley Massive Passive>Cranesong HEDD> L2>Apogee AD-8000SE>Cello Performance II amps>Dunlavy SC-V monitors
Dave Harris
 Studio B Mastering
Innominandum
« Reply #13 on: May 06, 2004, 12:17:20 am »
davidc wrote on Wed, 05 May 2004 10:35
Sorry to take this thread off-topic. Are you happy with these?
dcollins
« Reply #14 on: May 06, 2004, 01:54:26 am »
Quote:
B-rad axed:
Analogue source is ATR-100 transport with modded repro electronics and Flux Magnetics head -> Davelizer EQ -> MSEQ-2 (modified) -> 6386 Compressor (mostly stock) -> Custom 96k A/D -> tc 6000 -> HEDD 96 -> L2 -> Lavry 3000s to get back to 44k1 and Bob's your uncle; its "in the box."
Digital source uses the HEDD d/a which I quite like.  Seems a lttle "full" in the bass which isn't a bad thing for the most part.
Monitor dac is Lavry Blue, to custom monitor panel, blah, blah blah....
DC
