dave-G wrote on Fri, 14 September 2007 09:21 |
I'm curious to see what people have chosen as their in-house reference level for 0VU/+4dBu/1.23v from dBFS
0VU = -14dBFS here.
I get a really broad range of mix levels, from really hot to really low, but most of them in the middle, just barely touching 0dBFS on the hottest peaks. So I go for the "middle ground" of -14dB = 0VU DAC level, to allow for that variance.
I suppose you could leave it at -18dB and add an analog attenuator, like the Gold Point to lower hot mix levels to taste, rather than do it digitally in the DAW, or by changing your DAC output.
Curious why some guys go for -8dBFS, you gettin' much headroom on mixes you receive?
What level do you set your post analog loop ADC, same as your DAC?
Anyone care to describe their level calibration procedure?
I suppose every piece of gear in the analog path has an optimal operating range, somewhere between too much distortion and too much noise floor. Some of us find it according to specs, some of us find it intuitively, and most importantly by listening.
Perhaps an ME's "trade secrets" may be found in this area.
IMHO getting hot CD levels, that retain some decent audio quality, is found by careful consideration and experimentation with optimizing various levels, gain structure, using high quality gear at every stage, and of course the regular stuff; how you EQ, compress, limit, etc.
This could be a really interesting thread.
JT
