ram75 wrote on Tue, 04 September 2007 09:59 |
it can't be noiser than the mackie?
You'd be surprised! The Mackie, although a bit sterile and
anemic, are quiet mixers.
Quote: |
the soundcraft 600 is still available at 500 euros the guy said it needed a cleaning, but was fully fonctional i heard there was a great guy in paris for cleaning old desks
And you might wind up sinking another 1500 EU to get it working
in top shape.
The 600 was entry level compared to the other models.
There was also a "Live" version of the console which had no
patchbay and a slightly different monitoring in the master
section IIRC.
Find out it's condition, one person may say "cleaning" and it
actually may mean "re-capping and re-chipping" - new capacitors
and IC chips for every channel. Parts alone can cost up to
1000 USD. Keep in mind labour too...takes about 1-2 hours per
channel of work.
My wife's cousin wanted his Soundcraft Spirit live
mixer "cleaned"...I listen to it only to realize that some caps
are shorting out, a few IC's dead...
Do your homework first...check out the console really well.
Be prepared to interface you equipment with the console.
Those boards use ELCO connectors if I recall. Or at least make
sure you can play music and test a mic through every channel.
Quote: |
after reading the post all over i may pass on the D&R dunno about the soundtracs, i've read about neotek and soundworkshop but they are are invisible around here i have a question: wich one you recommend in the soundcraft, 500,600,1600,2400,6000?
thanx
I'm also not familiar with D&R other than a good reputation.
They're maintained a strong presence in Broadcast and Cimena mixing consoles in EU. Look into it a little more before you
write them off.
If you wanted a Soundcraft, a 1600, 1624 or a 2400 is more flexible (busses, routing etc.) The 1600 is oldest - 1979,
the 2400 is newest - 1989. Same sound from both. I've worked on a 1624, good sound, (and no need to push it too hard, don't try to "saturate" the mix bus running with the meters pegged at +3).
The Soundcraft 6000 would be real nice and the youngest of the
series you mentioned.
Also look into the TS-24. (even newer than the 6000)
You may also be able to find pretty cheap.
Mario
