Hello,
Thanks very much for the reply. I am not quite sure I understand a couple of things, and I want to understand you properly since you are taking the time to explain this stuff.
1.) You say, "Certainly if you want to come anywhere near the specifications that even shoddy digital filters readily attain, that's one huge analogue filter".
I do not want to seem ignorant but, do you mean the filter would have to actually be physically huge, or something else?
Also, at 192khz I thought the filtering could be pretty relaxed and still work fine. Would it still be too hard to have an analogue filter, even at 192khz? Maybe I am talking about a converter that only does 192khz.
2.) You say, "That's *when* it's worth the extra trouble of making the converter run faster, use more practical analogue filters and do the really steep filtering in the digital domain".
Did you mean to say "That's *why* it's worth...". If not, what is your word *That* referring to?
3.) You say, "Point is that halfband filters cut the number of calculations in half".
Does that mean half the latency, basically?
4.) Hypothethically, with a "money is no object" scenario, do you think it would be better to design a filter with no oversampling.
5.) I am still unclear as to how it is possible to do the oversampling if Mr. Lavry's comments about problems with faster sampling are correct. I mean, he is basically saying that faster sampling is less accurate, and that 96khz sampling is better than 192khz sampling for that reason. Is oversampling different than regular sampling somehow so that it does not need to be accurate?
6.) I do not really understand the "phase linear filter vs. non-phase linear filter" issue, so I guess I should do some research before I ask questions about all that. Latency is definitely an issue with Pro Tools overdubbing, unless you "direct monitor", which creates other issues. One thing I will say for the Digidesign 192 i/o is its latency is pretty low. I have some "high end" converters here now also. They sound lovely, but the conversion delay is longer. I guess that is par for the course.
Also, I see you are making DSD converters. Are you planning on making any PCM converters?
You mentioned Digital Audio Denmark, re: the chips with proper filtering. FYI, I spoke to the guys at Digital Audio Denmark not too long ago. I think they are still going with their "anti-aliasing" plan. They are using a crystal semiconductors chip, but I think he says they are only using part of it or something like that. They are oversampling at 5.66mhz and dividing down, as best as I understand it. I am interested in the DXD idea, but I am trying to learn more.
Thanks again for your help.
Faithful regards,
User of gear
