Doc Roc wrote on Mon, 29 September 2008 19:25 |
thanks guys. I ordered a few solid core doors. Now, once they come in, what would you recommend me do to fill in any air gaps? closed cell tape? any other/better suggestions? the frame is pre-hung as it is in an apartment complex (I will be using 3" screws to help secure the new heavier door). But as far as the door-to-frame space, what's good for that? Thanks!
This may seem obvious, but sometimes it isn't:
just ensure that your frames are as solid as you walls and doors.
I'm not sure what sort of door frame you have in place since it is a complex. But just check to be sure.
Also not sure how many hinges you have, but if you have 3, look at getting 4 going.
I'm about to embark on this myself. So, a sympathetic "good luck!"
