Klaus Heyne wrote on Mon, 16 July 2007 18:50 |
It's news to me that the term 'resolution' is quantifiable and can be attached to dB units. Please give a definition for 'resolution', and how you define a 5dB improvement.
As soon as you can define for us objective parameters of 'resolution', I will follow along.
The definition of gain in resolution which I use is this:
the equivalent increase in perceived detail level from the equivalent gain in volume.
For example, by turning up the monitors by 5db I have a perception of increased detail.
This perception of increased detail for a 5dB monitor gain increment is roughly the same as I experienced in the test.
Subjective it is but I would guess that if we were all tested and asked to guage (in dB) increase of detail against increase in monitor gain, we would likely have similar results. So perhaps we can agree on some pseudo measurement which we will all be able to relate to in some useful way?
Quote: |
In the meantime: Phase reversing (and thus pointing out any divergence between the cable and non-cable connections) still will need subjective interpreting in terms of musical meaning of these deviations- rather than assuming that the larger the deviation, the more useless the cable, you would need to decree what amount of deviation in what frequency band is least/most objectionable to the ear!
Alas, if we could make such measurements in a controlled way we could at least measure differences, which would render the subjective aspects as academic.
In any case, I would not expect to gain anything from phase cancelling as it would be impossible to get an actual cancellation. Impulse response tests would be more benefitial perhaps, but like I said, for anyone who can trust their ears, it is not a hard test.
Quote: |
In audio measurements, noise floor improvement and gain increase are not necessarily directly linked. Your cable-less connection may have seen a slight gain increase (though I very much doubt that it was anything more than maybe 0.5 dB), but any noise floor improvement would need to be separately measured.
Well, the noise floor issue comes easily as matching the channels audibly reduced the noise-floor. I was listening at varying levels up to very loud to check this.
Regarding the gain issue, my results were repeated many many times without alteration. A significant increase in gain but far more significant, a bigger gain in resolution.
Andy
