Ethan Winer wrote on Wed, 20 June 2007 09:18 |
Scott,
Quote: | I think my room might be too dead. The whole ceiling is covered in acoustical tile.
The larger problem is that the absorption is not uniform versus frequency. Most ceiling tiles aim to absorb speech frequencies only. This is fine for a classroom or doctor's office, but not so good for a control room.
Quote: | Should I do even more bass trapping
Yes. You didn't mention how thick the foam is, or what brand, but thin foam has a similar frequency-selective problem as ceiling tiles. It absorbs mainly higher frequencies so the room is too dead yet boomy at the same time.
--Ethan
Hello Ethan,
Thank you for your time..
The foam is 2" thick "Auralex style" foam. I'm thinking I should probably pull some of it down. The people in the room, before I arrived, did cake one of the walls completely with it and the a wall under the belly of the air conditioning duct.
One thing I did notice. Aftering building a wooden platform, for my drums, the Kick drum came to life. Setting up the kit on the thin carpeted, cement floor sucked the tone/life right out.
It's really really hard for me to fly traps in this room. The concrete pillar's are virtually impenatrible.I've gone through a number of expensive masonry bits, trying to drill holes for achors. So I'm thinking about making 2 more of these huge things and putting wheels on the short and long side. In order to position them accordingly for mixing or tracking.
I saw this on your site and thought that my room might benefit greatly from a few of these. Maybe fill it with some OC703 glass?
and maybe I could incorporate this with one side of the moving bass traps, I'd like to construct.
You mention "liquid nails" on your website. For mounting to cement. Is that strong enough to hang a bass trap with? Say.... 6" thick 72x48? With OC705, it gets pretty heavy. I'm using Bungii cords now and I'm preying it holds....
I apologize for any vagueness. I'm new to "Dialing in my room. I am amazed by how Bass Trapps seem like such a miracle cure.
and thanks again..
-Scott
