Eliott James wrote on Wed, 13 June 2007 10:14 |
The best way to use a DSD unit would be as a stereo recording device - performance directly to DSD. If you are multi-tracking with ProTools or other PCM medium, at 96/24 or 192/24, and then mixing to the DSD device, what you get is no better than what you started with.
You might as well preserve your 192/24 or 96/24 mix.
Now, if you could multi-track, add effects (plug-ons or other) and edit in DSD, then mix the DSD, then you're perhaps getting there.
Future proof... no such thing as we don't know the future and the technology moves so quickly... but again, it's no better than what you put in.
There may be some merit to mixing down from tape to DSD. If you believe tape captures more detail than 192/24.
Hi Elliott,
What I am doing is coming from multitrack Protools, out track-for-track through high quality D>A conversion into a large analogue console, wherein I am adding reverberation and hardware outboard where needed, and finally summing with the console's analogue stereo bus(s).
My point is to now capture that as my final mix on the highest quality format possible, be that 1/2" tape, or digital.
I think one will get a better result with the best possible format, and in this case one is not "limited" to the sample/bit rate of the original, because the original multitrack has at this point become something more than the sum of its parts .
So for me, if DSD is demonstrably better than 96/24 (which I had been using for digital mix archive before), or even analogue tape, then why not go to that?
As for "future proof," of course nothing is ever truly so. But if one archives at the highest possible rate, then one is most likely to fit into the most number of possible formats...until the future rears its head with something higher! And this 5.6 is twice the resolution capability of SACD.
Best regards.
