Hey Guys,
Thought I would chime in on the Focal's.
They are the smoothest monitors I have come across in my short lived life.
As for the Solo 6's
I have found that they translate well and are amazingly detailed and accurate.
They really have great accuracy in the lower octave. I can really hear the full depth of the low end. It will force you to make changes you might not make with some other so called "reference" monitors.
I find that I can listen loudly, for a longer period of time, and not get any ear fatigue!! This is a very, very important thing to me because I tend to not give myself any breaks while I am working.
It's a work ethic thing!
The stereo image is also very wide, you can sit in the mix position, while your client or producer can stand of to the side of you and still hear the same sweet spot.
This can make your life a whole lot easier,
I'm sure we have all had clients that hear shit that's not there, right???
Hence the Producer Fader!!!!
The Twins 6's have a slightly different mid-range and low-end texture, simply because you have another woofer and amplifier taking care of the low end.
The Twin's have a very cool feature, they have switches on the back that determine where the low end speaker will be, on the inside or the outside. It is all up to you. I like the low woofer to be placed on the outside. Should you decide to
place them in a vertical manor, just inverted the switch and you will have the low end woofer on the bottom.
It is all really up to your room and your sense of aesthetic.
I have some clients who prefer to have the woofer under the mid-range, they claim the kick is more "out-front". This sort of mirrors speakers in the wall.
check them out
http://www.focalprofessional.com/en/products/SM6-home.html
