bblackwood wrote on Thu, 09 August 2007 14:46 |
David Glasser wrote on Thu, 09 August 2007 15:32 |
Full report soon.
Please report back ASAP...
Well Brad, as promised, this is for you?
I have soundBlade up and running with the new Sonic 303 interface (firewire, 8 AES I/O + DSP). I've got 3 options that I think are essential: NoNoise Manual Declick, DDP Loadback, and the Multichannel option. The system has some I/O and editing limitations w/o the Multichannel.
System configuration is a bit convoluted - several pieces of software are required to get audio in and out of sB and the 303 - not the simple plug and play that I was used to w/ Sonic HD. But it seems to be behaving. The 303 contains a massive amount of DSP and signal processing that can be inserted into sB, but I haven't popped the hood on that yet.
If you've used Sonic HD, the main difference is speed. Otherwise, it looks much like an upgrade of HD. If you haven't used Sonic HD, prepare for a bit of a learning curve. The Sonic editing paradigm is unsurpassed; couldn't work without it. I'm a neophyte to plug-ins so I'm not doing much with that yet.
One great discovery is that soundBlade and PTLE will run simultaneously on the MacPro with acceptable stability - I know folks with PCs can run 2 soundcards and 2 instances of software. Now I can finally do something similar on a single computer - play from PT and capture to sB, using the same hard drive (an internal SATA drive). Once we get all the timecode stuff working, I'll be able to run sB & PT locked together.
Sonic HD has always been able to use a variety of file formats mixed together in the same EDL; sB now properly recognizes .L and .R suffixes instead of just .1, .2. for channel grouping. sB will write AIFF or BWF with metadata. Sonic HD projects and EDLs are readable by sB.
Manual Declkick now works on interleaved files - a huge improvement - it means that clicks can be removed from DDP masters without going back to the original EDL. For burning CDs, sB creates a DDP Image first. I'll miss the ability to cut multiple discs at once w/ cascaded CDW-900es, but that's progess.
The reason it's taken so long: along with the new Sonic stuff, I added a spiffy new DVI display that's switchable between 3 computers (and naturally had to upgrade some video cards, drivers, and KVM extender hardware): a G4 running Sonic HD, PC running Sonoma, and the MacPro running sB and PTLE. We also added AES, WC, and TC cabling for the new system so it would be a simple matter of swapping cable bundles to change over to sB as the primary system.
So Brad: if you're jonesing to move to a Mac (and who isn't) and you have some money burning a hole in your wallet, go for it. Sonic will be at AES with some new upgrades I'm told.
