rankus wrote on Tue, 05 June 2007 18:27 |
But most of the time (rock) it looks like Fibes' setup.. One mic = one amp... (121 usually) If it's metal (or Nu-Metal, "Modern Hard Rock") I will multi-mic and take DI's etc.
The photo isn't reality as far as the amount of mics that are up.
There is another room mic up and for this particular take the 57 was "on the wood" behind the amp.
There are normally 4 mics up for one of these rolling sessions:
1. Some sort of traditional dynamic like a 57, 421, D12 (yeah meaty metal).
2. A ribbon like the 121 or another of that ilk.
3. LDC like a U87 or M269c
4. and of course an omni starting with a Bova Ball, LDC in omni or one of them thar Avensons.
Using cue mix I can turn them on or off and blend to my liking, arm the tracks required and we're ready to roll. If i have a console at my disposal this stuff gets printed together if it is be mono or on discrete mono tracks if it's gonna be stereo.
Whilst doubling i tend to shy away from the same mic, amp or distance almost exclusively.
Unless I'm going for some crazy panned/phasey room effect solos are by and large one mic which helps with editing takes and gives the up frontness required.
There are also usually (in addition to the combo open back speakers) two closed back cabinets of varying speaker wattage ready to go in the line. There is a 4x12 just out of the frame to the right in the photo.
Sometimes, when the amps brought in are of dubious nature I split from the STD(tm) and run my version simultaneously so as not to mess with the artist but give me options just in case I'm dealing with a dog. Sure, i could argue amps before the take but I've found it to be detrimental to the inspiration process.
And then there's the leslie in the iso ready to roll.
