Ok friends, I am having some low end resonance in this room that I am trying to futher tame, but with mixed results. Beautiful octagon ceiling that slopes up to about 16ft. in a room 30'x 22'. Except for the octagon insert, ceiling height is 9'6". Well, after the room was enclosed with doors and windows it became apparent there was a honking resonance while standing on the floor smack in the center of the octagon shape. Is it the room shape or the octagon shape that is creating this? Or a combo? At this point we have tamed the low end RT with 705 1.5" baffles as you can see configured in the panned out pic. It was designed by the same acoustic guru(?) that created the space to begin with. Well, it works...kinda. Still have a honking in the center at 142Hz but not so bad that I can't work around it. It's still to heavy in the broadband bass frequencies as well as the resonant one for my liking.
I'm thinking that these octagon angles must be a contributor of bass buildup in the center cause that is the only area that exhibits an acoustic problem. This shell design for some new trap is totally my idea. I see that is the only area that is exposed to some kind of crosstalk between octagon panels.
If this is a resonable approach what do I finish these as? Do I fill with 'chunks' of 703 and frame and fabric. Or a plywood panel on one side with 703 or fluffy stuff and fabric cover. Or something else altogether? The measurements for this shell are about 4' across 2'2" tall, 1'9" deep.
The room now is lively in a good way but I tend to prefer a little less. The walls behind the fabric are most varying 1.5in. wood designs that mix things up. There is some 1.5" 703 on about 25% of the wall. Horizontal ceiling sections are all 1.5" 703. Within the octagon there are 2in. half wood rounds in front of 703. A 2x4 section on each octagon panel has been broken out from the attic side and replaced with a limp membrane (forget what it's called) covering it against the 703. This was the first thing that was attempted to rid the room of low end buildup.
Again, it has improved but I think my area of concern might be helped further with more trapping.
Thanks for listening.
