My mix room is square (23ft wide 22ft deep and 8ft high).
I have 4ft wide 8ft high by 4" thick 703 traps in each corner, two 4ft wide 6ft high by 4" thick 703 traps behind me 10" off the back wall, three 2ft wide 4ft long by 4" 703 traps lying along the front wall to floor corner, and a 4ft wide 10ft long by 4" 703 ceiling cloud 4" off the ceiling, these make up the "fixed" traps in my room.
Also i have two 4ft wide 6ft high 4" 703 traps on wheels that I have on both sides of the mix position which are 4ft from the side walls and 4ft from either monitor and 5ft from the front wall.
Mix position follows the 38% guideline.
My question is, having the traps positioned away from the walls by the mix position (and/or other positions) help change the room characteristics away from being a square room, or does it just help first reflections?
(I am tempted to build another pair of 4ft wide 6ft high rolling traps to help shape/control sound in the rear of the room by positioning them well of the walls as needed).
I can post a pic if discussion warrants it?
Thanks Francis for sharing your experience in this forum.
Mike
