i'm tired of moving those racks around, they don't look good in a fixed install, and i don't even have a vehicle to move them......if i REALLY need a piece of gear for a track session i can just pull it and take it with me.
speaker stands.
the base is microlam (material used for headers in new home construction)
polls are 1.5" galvanized steel pipe attached with 1.5" galvanized flanges. i had them cut and threaded at home depot.
the top plate is two pieces of 1"x12" pine glued and screwed together. i then used a planer to make a 45 degree angle on all edges just to give it a nice finished look.
half a cinder block for base weighting (should have spray painted them.)
then i set the base spikes using a drill press, screw in the threaded inserts, screw in the spikes......
i then cut 3" square pieces of masonite to keep the spikes from digging into my carpet
i also used those "shims" to level the stands as my floor is uneven. i got the spikes at:
http://www.oregondv.com/
