Tomas Danko wrote on Wed, 02 May 2007 12:46 |
There are several valid points that you make, Brett.
However, I would agree that parts of Logic has a high threshold when it comes to figuring things out. This is the price for being a fully object oriented environment.
Not even the metronome is hard coded. It's "built" as an object within Logic. This gives the user a lot of power to accomplish things, at the cost of a steeper learning curve.
I'm a dedicated Logic user myself these days, so I may be biased. I still do think there are easier DAW's to wrap your head around at the get-go.
Then again, coming from Cubase or Pro Tools I'd say one should be able to compose music the very first day.
Ok, sorry for the hi-jacking of the thread!
Not at all. Very relavent indeed. I used Cakewalk, then Cubase, then DP, Then PT , now Logic. So, as you can see, I should be able to pilot any DAW, and I can. I used Logic first day with no problems. I didn't have a manual and didn't need it. The only thing that did get tricky was using multi-timbral Kontakt midi channels. HAving to create an object and input it to that channel with the midi channels activated was a little cumberson to figure out. Took me about an hour to figure it out. Protools is the best layout I have seen. Having everything accessible from the arrange window is brilliant. But the midi and editing options are limiting.
Even the piano roll and editing graphic resolution is horible in PT. But, it is snap to learn. Probably the easiest.
I always like Cubase. And Cubase SX sounded great as well. Cakewalk Sonar was pretty cool too but a little to power hungry back when I was using it. I ended up upgarding to a mac and DP. I have found my way to Logic after working on a film with a composer who used it. I love it now!
Not saying I won't buy Protools HD at some point but it doesn't make sense for me at this point. Logic does what I need and the new macs are so powerfull. So, my upgrade from my mix/logic system g4 dual 1.42 with an apogee 800 front end, will be to symphony and a new macpro.
The only thing keeping me on the PT rig was the plug-ins. Soundtoys, Sony, DaD... Now the ones I love are going to Native, so there is nothing holding me back.
Also, I use all in the box synths and modeling fx and PT hardware doesn't help when running those. It's all about native power anyway. I run BFD, Kontakt2, Amplitube, and Convo Verbs. PT HD doens't help make those work. So the MacPro is the next investment as my dual 1.42 bogs down when running these apps in usable numbers. I have to freeze and bounce to use them now.
It has never been a mix issue as it has been a native battle. So dedicated mix hardware is kind of useless to me. Symphony will do fine. With 1.5 ms latency I can real time monitor as well.
