j.hall wrote on Wed, 02 May 2007 17:37 |
no comments on the recalls?
Big kudos for the vocals, bringing them up more does not only fit
my personal taste better but also fills out that frequency hole
I mentioned much better, making the mix more dense.
And the BG vocals work better with the vocals now.
The kick/bass in the verses is good, but I'm not yet completely
happy with the chorus, it sounds like you had brought up the bass,
but didn't reduce the kick.
If the kick/bass ratio was something like 80/20 before, it's now
80/30 and I'd like to see it in the 70/30 range.
On my mixing monitors, this isn't much of an issue, but when I
listen to it on my mastering monitors (which are (more or less)
linear down from 30 Hz to whatever) it shows up that there's too
much low frequency information there now.
I'll post my comments to the recall of briefcasemanx's mix later,
I have to listen to both mixes again.
Thanks a lot for your time, it's mucho appreciated.
Tom
[Edit:] Oh, and I just noticed that the transients of the kick
got lost a bit, so if the loudness of the kick is reduced even
more it'll need most probably some EQ work to bring it back.
