Hi Lars
With regards to the anechoic camber, I’ve been trying to find the commission data, hopefully post it next week, but the wedges are 0.95 m long indicating a combined porous absorber length of 1.90m meaning at first glance the room is fully anechoic down to 45Hz using the ¼ wavelength assumption, however were fortunate to have Trevor Cox of RPG acoustics as one of professors and I suspect he probably used a form of resonant absorber to soak up the rest of the low frequency energy. As I say ill pester someone for the data and hopefully post it next week. I cannot book the chamber at the moment I will be able to as of September this year to research my dissertation.
With regards to the question of perfect loud speaker, and measurements, the goal must surely be for something that produces precision of accuracy in reproduction that is bellow the average human threshold of perception.
Anyway its all very well making a statement like that but what do I think it means in measurements. This is a really busy time of year for me so I dont have a lot of time to throw at it, so for the moment I’ll do freq response ill get round to the rest over summer.
I made some random number generators in matlab and off axis co-efficient, low roll off, freq variation ect. So I can put in theoretical performance criteria and generate something like the data I might get if I performed my 1, and 2 freq response measurements.
If I plot it as 180o on axis, in a 3d mesh I get graphs showing the speakers complete frequency response, there would be another one at the second distance but who knows how they would correspond, I’m not even going to try and simulate it, for now ill just do these 4. sorry the z axis is a bit wrong but you get the idea.
Below what a crap speaker might look like, +-5dB ect
ok_speaker2 is on axis +- 3db, Bessel function behaviour above 6 kHz, roll off at 50Hz with an off axis variation multiplier of 0.7, a fairly typical hifi loud speaker probably, If I ever do the test I expect to see results similar to this.
good_speaker2 is on axis +- 1 dB Bessel function behaviour above 15 kHz, roll off at 30Hz with an off axis variation multiplier of 0.3. I recon even the best loud speakers would struggle to better this,
perfect_speaker2 this is the point of theoretical inaudibility, all frequency variations at all points less that +-0.5dB with in the audible range. A this point I would suggest further improvement would be futile as most humans can’t hear it.
I don’t know if perfect_speaker2 is possible but I think it should be a goal in performance, but without testing how will we ever know.
I hadn’t heard of KLIPPEL but it does look fairly comprehensive, perhaps the loud speaker industry should use it to standardize some more comprehensive testing.
