If you want to know that, mix two stereo or four mono signals from different sources together, all with the same clock, pan it as you like, use any gain setting, it does not really matter. By routing the same sources into 4 other channels, using exactly the same levels and pan, but switched in reverse phase, the netto result should be 00000. If this works, digital mixing is clean. If you would do this trick with analog mixing, you will keep always a residue of noise and sound.
I am mixing digital since 1995 (Weiss), and I would not like to go back to any analog desk, although I do respect that others may find digital mixing not satisfactory, I doubt if their conclusions are based on the correct facts. Mixbusses with transformers give a nice signal soup of delicate distortion, just like the 1:20 step up transformers in old desks, which were a need to avoid noise in those days, but nowadays honoured as the only way to good sound.
Schallfeldwebel
