Pages: 1 ... 8 9 [10] 11   Go Down
Author Topic: session quotes  (Read 33283 times)
Chris Ilett
Re: session quotes
« Reply #135 on: January 12, 2008, 08:17:36 am »
Even though your mix makes the song.  Cool
j.hall
Re: session quotes
« Reply #136 on: January 12, 2008, 02:03:22 pm »
Chris Ilett wrote on Sat, 12 January 2008 07:17
well, in my case, yes it  does........................................................ ............
HA
R. Koehler
Re: session quotes
« Reply #137 on: January 22, 2008, 05:25:01 am »
Not necessarily a "session" quote - but a mix quote...
So, I'm on aim with resident forumer D. Combs talking about a mix that he's rendering out in Sony Vegas.  He's having problems with the render (I forget what exactly) so I tell him to check his plugins to see if they're causing errors.
A few minutes later and the infamous words are uttered:
D. Combs: "Ah, I found the problem."
Me: "Yeah?  What's going on?"
D. Combs: "It was one of the compressors I was using."
Me: "What was it doing?"
D. Combs: "Compressing."
Confused Not the answer I was looking for, but oh well...
T. Mueller
Re: session quotes
« Reply #138 on: February 07, 2008, 02:15:26 pm »
j.hall wrote on Sat, 12 January 2008 13:03
HA
I concur.
grantis
Re: session quotes
« Reply #139 on: February 18, 2008, 05:26:59 pm »
When speaking to another engineer about a particular piece of gear, I asked:
Me: 'Does it have Toslink out'?
Engineer: 'No, only 8 channel digital optical'
O...K...
Grant Craig
Nuovo Music (Me)
Skiddco Music (Where I work)
Work History (Well, some of it anyway)
iCombs
Re: session quotes
« Reply #140 on: February 20, 2008, 06:58:45 pm »
grant richard wrote on Mon, 18 February 2008 16:26
O...K...
...Which is actually ADAT Optical...and not TOSLink, which is S/PDIF Optical.
Ian Combs
Producer/Engineer
Lightspeed Group, Inc.
"Mista apareeatah... can I have maar beass at all frequencies?"
grantis
Re: session quotes
« Reply #141 on: February 20, 2008, 10:20:30 pm »
you're proving my point for me.
Grant Craig
Nuovo Music (Me)
iCombs
Re: session quotes
« Reply #142 on: February 21, 2008, 01:32:02 pm »
I'm just saying that dude was right...it didn't have TOSLink.
http://en.wikipedia.org/wiki/TOSLINK
Now if by my understanding the difference between TOSLink and ADAT optical is making your point...then I guess I'll just shut it right now! Very Happy
Ian Combs
Producer/Engineer
grantis
Re: session quotes
« Reply #143 on: February 21, 2008, 02:50:19 pm »
"TOSLINK is a standardized optical fiber connection system. Its most common use is in consumer audio equipment (via a "digital optical" socket)."
Did you read the first sentence?
Grant Craig
Nuovo Music (Me)
iCombs
Re: session quotes
« Reply #144 on: February 21, 2008, 03:28:47 pm »
Did you read the rest of it where it differentiated TOSLink from ADAT Optical?
Quote:
Occasionally, one may encounter terms for technology similar to TOSLINK, such as ADAT Lightpipe or simply ADAT Optical. This is most often seen in the professional music/audio industry. While the ADAT Lightpipe format utilizes the same JIS F05 connectors as TOSLINK, it should be noted that the ADAT Lightpipe format is NOT compatible with S/PDIF.
...same connector...different digital format.
Like saying that AES is the same thing as Balanced Analog on an XLR because the connectors are the same.
Ian Combs
Producer/Engineer
grantis
Re: session quotes
« Reply #145 on: February 21, 2008, 03:39:00 pm »
you continue to prove my point.
me and the fellow engineer were talking about the same connector.
as you and i are talking about the same connector.
Grant Craig
Nuovo Music (Me)
iCombs
Re: session quotes
« Reply #146 on: February 21, 2008, 04:03:17 pm »
It's not a "TOSLink" connector.  It's an optical connector.  That's used for multiple formats.
Methinks the engineer knew enough to know the difference.
Perhaps the pot should take a look at its color before it berates the kettle.
Ian Combs
Producer/Engineer
grantis
Re: session quotes
« Reply #147 on: February 21, 2008, 04:25:24 pm »
duly noted.
so when I purchased my cable labeled "TOSlink" for my "ADAT optical" or "Digital optical" or "Digital lightpipe" or "whatever you want to call it" device....I purchased the wrong cable?
and if so, why does it work so well?
Grant Craig
Nuovo Music (Me)
iCombs
Re: session quotes
« Reply #148 on: February 21, 2008, 04:50:18 pm »
NO...but on my MOTU 828, why does is differentiate between TOSLink and ADAT on its optical output?
I know you think I'm splitting hairs, but it's an important distinction.
You definitely aren't gonna get 8 channels of audio into the TOSLink optical ins on a G5.  Same cable.
This is one of those things where specificity counts for something...and where assumption can get people into trouble.  It's not a semantic thing if there really IS a difference.
Ian Combs
Producer/Engineer
eljaron
Re: session quotes
« Reply #149 on: February 26, 2008, 04:30:26 pm »
This cable discussion isn't funny at all.
Pages: 1 ... 8 9 [10] 11   Go Up
