Author Topic: U47 microphone capsule?  (Read 2975 times)
Oleh Malyy
  • Real Full Name: Oleh Malyy
« on: October 10, 2011, 02:31:40 pm »
Which capsules was used in Neumann U47 microphone?
In the web are a lot of information that M7 and K47 was used in U47.
But in documents "docu0101_Mictab_E 10-2009.pdf" and "docu0100_Mictab_D 10-2009.pdf" from Neumann we can see, that in U47 was used M7, K49 and M48 capsules.
And K47 in U47FET microphone.
Where is true?
klaus
Re: U47 microphone capsule?
« Reply #1 on: October 10, 2011, 02:43:19 pm »
Neumann used two capsules as original equipment in commercially available U47 (tube) microphones:
First the M7, from 1948/9 to ca. late 1959, and thereafter the K47/49. The latter was also used in the U47fet (and is still used in the M149, and M147.)
The K47 was also used since 1960 as replacement capsule, when a U47 with defective M7 came in to Neumann repair facilities.
The "M48" you mentioned was the KM53 small diaphragm omni capsule installed in the short-lived Philips (U47p) model (ca. 1954 to 1955). It had detachable (bajonet) heads equipped with  M7 or K53 capsules.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
