As a package I think it's a good combo.
I thought of getting one of these a few years back when I was debating between full dig or hybrid system, but I went with a large analogue console in the end.
You might be limited on inputs with the 002. I think you can get a second 002 to use in tandem if you wanted. Look into that.
Get a real good, fast, with lots of ram computer so you can run all the EQ and Comp plugs you want.
The nice thing with that setup is that you'll be pretty much ready to go out of the box. Control surface / monitor section / pre's.
The Focusrite pre's in the Control 24 are pretty good too, they're not API's, but very usable if you don't push them too hard. They are the same as the Focusrite Platinum series and you get 16 channels worth. Although there is no digital out's on the Control 24 only analogue line out and analogue monitor returns.
The other advantage is that if you ever upgrade to HD, you've already got the console.
MI
