Pages: 1 2 3 [4]   Go Down
Author Topic: Neumann U48  (Read 41067 times)
Oliver Archut
Re: Neumann U48
« Reply #45 on: February 10, 2010, 06:45:54 PM »
Depending how you hook up your meter something around 16 to 26 Ohm.
Best regards,
Oliver Archut
www.tab-funkenwerk.com
J.J. Blair
Re: Neumann U48
« Reply #46 on: February 10, 2010, 07:14:00 PM »
Greg Norman wrote on Wed, 10 February 2010 15:20
This was bought from Bill Bradley like  J.J suggested.
Not to bag on him, but ... I find it hard to believe that he's the one well known tech who insists on using solid core wire in very high impedance positions.  Coincidentally, he's the same tech that did not pad the resistors in a M49 he serviced, leaving it unusably microphonic.  It seems odd that somebody with that much experience is so unaware of this issue.
Maybe if he participated in this forum, he would learn these things!
studio info
piedpiper
Re: Neumann U48
« Reply #47 on: February 11, 2010, 01:07:14 AM »
Sorry if this has been covered, but what exactly is the issue with "using solid core wire in very high impedance positions"?
Tim Britton
row, row, row your boat...
johnR
Re: Neumann U48
« Reply #48 on: February 11, 2010, 01:43:36 PM »
piedpiper wrote on Thu, 11 February 2010 06:07
It can be microphonic, ie. sensitive to mechanical vibration. In a lower impedance circuit any signal generated by this is more likely to be shunted out by the circuit impedance, but in very high impedance circuits it can be a problem.
Greg Norman
Re: Neumann U48
« Reply #49 on: February 11, 2010, 02:19:48 PM »
Oliver Archut wrote on Wed, 10 February 2010 17:45
Thanks!
piedpiper
Re: Neumann U48
« Reply #50 on: February 11, 2010, 08:15:19 PM »
johnR wrote on Thu, 11 February 2010 12:43
Thanks John.
Tim Britton
Oliver Archut
Re: Neumann U48
« Reply #51 on: February 11, 2010, 08:36:59 PM »
To put it in better perspective, a microphonic tube is in the end a condenser mic. The movement of the electrodes polarized by any operating voltage creates a capacitive difference that produces an electric signal.
Something similar happens when a solid core wire is used; if you use a stranded wire you mechanical short out that possibility.
If you use a solid core wire with a high dielectric property (capacitive amplification) like Teflon, you have a bunch of microphonics.
There are several ways to counter act this problem...
Oliver Archut
Klaus Heyne
Re: Neumann U48
« Reply #52 on: February 12, 2010, 02:39:06 AM »
...like either avoiding solid core wires altogether, or if you absolutely must use one, dampen and arrest its movements with a (high impedance) adhesive.
Klaus Heyne
German Masterworks
www.GermanMasterworks.com
MDM,
Re: Neumann U48
« Reply #53 on: February 12, 2010, 04:33:14 PM »
I wonder if using very thin solid-core wire might improve things.
I must study politics and war that my sons may have liberty to study mathematics and philosophy .. in order to give their children a right to study painting, poetry and music.
John Adams (1735-1826) 2nd President, United States
monoman
Re: Neumann U48
« Reply #54 on: February 13, 2010, 06:27:13 AM »
How about Litz?
Brian.
Brian Clark.
KaiS
Re: Neumann U48
« Reply #55 on: February 13, 2010, 06:54:46 AM »
MDM, wrote on Fri, 12 February 2010 15:33
No, it's even worse: the thin wire resonates at higher, more audible frequencies if there is no dampening isolation around.
With plastic isolation it can be an improvement.
The capacity depends on the size of the surface.
Therefore the side effects are reduced with thin wires.
Reliability can become a problem - thin wires tend to break, specially at the soldering joints, where smooth copper turns to hard bronze alloy.
You could use silver wire, best with foam isolation, like in high Q HF cables.
Regards
Klaus Heyne
Re: Neumann U48
« Reply #56 on: February 13, 2010, 02:18:41 PM »
Assuming no clear sonic advantage of using solid-core wire in the high-impedance section of mics (except when purposely boosting high end, by using certain types of Sterling wire) and nothing but trouble with its reliability, microphonics and solder adhesion, I see absolutely no reason for ever using it in the first place, other than cost.
But even there: how much do a few inches of multi-strand wire, like 96-strand Gotham GAC 3 material, cost? Pennies!
Klaus Heyne
German Masterworks
Eric H.
Re: Neumann U48
« Reply #57 on: February 19, 2010, 06:15:48 PM »
This thread  got me thinking:
How much is vintage a vintage mic that has most of its passive components renewed?
And would it be possible for a 40+ years old microphone to still work nicely with the same components it had since it first left the factory?
eric harizanos
Pages: 1 2 3 [4]   Go Up
Page created in 0.106 seconds with 19 queries.
